I have a “home” network with a number of Mikrotik components. On my property are 4 APs, all running 7.1.x. One of these is an Audience (running 7.1.3) that is running Capsman and controlling the others. The main router is a CRS125. I also supply internet to some of my distant neighbor (in a rural area) via some SXT PTP and PTMP wireless links. (These and the main router are running routerOS 6, not 7). All devices are connected with ethernet to the CRS (except for the remote neighbors, obviously). All was working properly until I added an hAP ac3 to the network for testing. I configure the hAP ac3 (running 7.1.3) as a switch/AP using the Quickset option for CPE after resetting the device config to defaults. I assign it a unique static address on my network and turn off dhcp on the hAP.
As soon as I connect the hAP to the network, the network becomes unstable, seemingly dropping layer 2 packets, A ping plot to my remote neighbors show that no traffic gets through. If I disconnect the hAP ac3 the network stabilizes in about a minute. No errors show in any logs. After trial and error, I discovered that if I disconnect my Audience (running capsman for the APs on the local campus only) the network works find with the hAP ac3 connected. I conclude that this has something to do with the Audience. If I disable Capsman manager and ipv6 on the Audience, the network still becomes unstable when both the Audience and hAP are connected. If either is connected by themselves, no problems are visible.
Any suggestions on what is causing this or how to debug it would be appreciated.
