Audience router as AP only
Hi, some basic question and hope nobody here will be offended. I connected Audience router via eth1 port to my ISP router. What shall be configured on Audience router to use DHCP from my ISP’s router. What I need is to continue using the same IP address range ie 192.168.1.0/24 all over home. Now my Audience router acts as bridge and provides its own DHCP and network range from IP 192.168.88.0/24.
How to configure Audience router that eth2, wireless 1,2,3 ports are using DHCP from ISP router ? Thank you.
you can try to configure bridge all port
What I do is I reset configuration, I check no default configuration, then when router boots up I put all interfaces to the bridge, assign IP address to the interface going to the router (make sure you use unused IP address and then reserve it on your router) and i put DNS address, i put my dns server address but you can put google address or your router address.
Please do not use multiple threads for the same issue(s)…
MAIN THREAD IS HERE → http://forum.mikrotik.com/t/dhcp-from-isp-s-router-in-audience-router-as-ap/167478/1
