Audience vs Eero?
That seems to be the product its built to compete with.
Anyone done the comparisons yet?
What is Eero? :open_mouth:
mesh WiFi
https://eero.com/
I have 2 in bridge mode. Excellent wireless coverage. I did order Audience to give it a try.
Eero is what the guy who has NO BUSINESS AT ALL TOUCHING A NETWORK, is bringing into a commercial install.
Sparky, “I use this all the time.”
Me, “YEAH IN HOUSES. You can’t do multiple SSIDS or VLANS beyond 1 for Guest. We have a VLAN for the control system… 1 for the Point Of Sales… 1 for Voice of IP… 1 for the back of house managers… 1 for the wait staff… Then one for Guests that has to work on a schedule…”
Sparky, “Well it works in homes…”
Me, “This ain’t your home.”
I got to work with the Eero system in a home for the first time last week. Yeah… a MORON could put them in.
Coverage gave you bars all over the house. But pings and actual throughput… not so impressive. Also I was curious what would happen if they put some IP video cameras on the system. Between the fact that I saw a bunch of units and not a lot of channel separation… wonder how much worse it would get if I flooded the backhaul with traffic…
But I digress.
I have used and LOVED Mikrotik for routing for a long time. But… every time I buy the latest wireless devices from Mikrotik… I sure get that Unpaid Beat Tester Feeling.
wAP AC, hAP AC2, cAp AC… all seemed to go through real growing pains.
So the question begs… since Audience is fresh out of the gate… how were they doing?
Haven’t tested Audience yet…
Am just curious to check how they are configured because i ve tested wireless dynamic Mesh in the past but i wasnt very happy with the performance…
Rather confused why you quoted me and posted this rant. If you are indeed referring to me personally, I do no commercial installations, just my own little home net. :open_mouth:
Proximus…
No Offense to you intended at all.
My rant was an actual back and forth at a job I was working on last month.
If how my phone bunched the responses made it look like a shot at you… I am sorry.
However… I am seeing a considerable amount of LV type contractors flipping to Eero.
Sparky of course…
But the Heating and Air Conditioning guys.
Audio Video Guys.
Security Contractors.
Solar Panel installers.
etc
Basically… a lot of the trades I interact with are starting to “just use Mesh so we don’t have to run wires anymore…”
Thank you for clarifying this. All good.
Distros in the US are sending out “we have Audience in stock”.
But still not seeing anyone saying… “Yes I have used it… And…”
Everybody is waiting for you to share the experience :wink:
While I used to LOVE TESTING STUFF OUT AND BEING FIRST...
Not getting paid, and ending up holding the bag on thousands of dollars worth of crap over the decades... might have sullied my enthusiasm. A little...
Information and capabilities for the Audience Mesh is very sparse … specs looks interesting but not interesting enough for me to make a trial investment without much further usability information. MikroTik should show off some real world application to demonstrate Audience Mesh properly.
I have 2 days of (limited) Audience testing experience now:
  • Audience looks nice, actually smaller than on the pictures, a device you can actually keep outside, close to TV or sideboard
  • it has 3 color LED that shine nicely through little slot on lower front side (including Mtik preferred blue led! but no more that bright :smiley: )
    No idea yet what they mean in terms of device status, but looks good!
In terms of HW it has 3 Wifi master interfaces:
  • 2x2 2.4GHz Wifi (IPQ4019)
  • 2x2 5Ghz Wifi (IPQ4019) (can only use channel 36 to 52(?))
  • 4x4 5GHz Wifi (QCA9984) (can only be used on channel 100 and above (I have European model))
There seems to be no additional SW/functions for MESH such as steering, improved access lists etc.
But maybe within Capsman there could be some additional functions (I don’t use Capsman …)[/list]
I did some quick setup and test as a dual band AP (2x2 2.4G + 4x4 5Ghz) to compare to RB4011.
To use all three bands as AP I need a bit more thinking how to organise my network…
  • 2.4GHz Wifi coveres slightly less distance than that of RB4011 (but RB4011 does have a great range)
    I have some far away IOT devices which have sometimes some disconnects, but they are really far off…
  • 5GHz 4x4 Audience has huge improvement over 4x4 5Ghz of RB4011. I get 5G conection for many clients now where before
    they stayed on 2.4Ghz.
    Now I can not tell if this is due to the Wifi channel difference as Audience only uses channel 100 and above!
    For the experts to tell (and more testing to be done).
  • I see no issue with DFS/radar on 4x4 so far (those 100+ channels are DFS channels).
Based on this, to cover huge homes or areas using two or more Audience seems to be a good way to provide
Wifi coverage.
A bit more tricky is going to be the setup / config, specially if you will use 3 AP Wifi interfaces (and not as MESH).
Which 5Ghz network will a client select if you have 2 with same SSID at two different channels? Or create 2 or 3 different SSID?
Creating the right access rules with signal level will be more complex, maybe not practical at all.
And seeing 3 master Wifi i/f with all (for me 18!) the virtual Wifi i/f means you quickly get lost in what is what…
But hey this is why you have such a device… :laughing:
Will definitely keep it as my main Wifi router… !
Running two 5GHz channels with same SSID in the same spot is definitely and utterly a non-sense.
If one is currently running a few VAPs off same physical radio, then dual 5GHz radio offers ideal opportunity to split them. Use the 4x4 radio for the high speed/volume SSIDs (such as IoT and guest access) and keep the low speed SSIDs on 2x2 radio.
I have been using Mikrotik since V3. I do know a lot, but there is more I do NOT know.
I got 3 Audience devices to do a job, since the write up about them fit my application.
I have spent days to get them to mesh (still no success) The insert that came in the box describe amongst others the led’s and the “WPS Sync” button functions for automatic “linking” The guide available on the net ( https://i.mt.lv/cdn/rb_files/1568200626Audience%20-%20qg.pdf ) differ from the printed one and also yield no success if followed.
I will have to use Winbox or CLI to “manually” mesh???
If a non networking savvy member of the public would buy this device, I can not imagine they would get it working. It is certainly a a aesthetically pleasing device.
Can any one maybe point me at a “guide” that actually work, that I can follow? Or just some pointers or tips please.
How to generate interference and mess up one’s airtime…
PPJ, I am sorry but I only have one device so can not really help you.
I would open a new forum post to ask help on set up as MESH solution
Actually all 3 Wifi radios are working in 3 seperate frequency bands, so no interference at all.
And I think that proposal by MKX (put high speed on 5Ghz high band)
is exactly what I will try out to get even more speed/capacity of the system.
I tested the meshing a couple of days ago.
  1. power up the 1st Audience which you will use as the main AP
  2. press the wps-sync button briefly, the light on the front starts flashing green
  3. power up the next Audience device whilst holding the wps-sync button, keep holding until the light on the front flashes lots green and orange
you should then find that it has connected back to the main AP, and capsman is managing the interfaces.
Note if you wish to add another one, you have to pair it with the first main AP, you can’t add it to the 2nd one. Well it didn’t work for me…
Hope that helps
Nick
Actually you can pair an audience to any of the already paired audiences
