Audience wlan3 APtoAP stability issues
Randomly (once an hour) the wlan3 link will go down for a very random reason.
The Client AP will start doing a background check, then up to 10 seconds later, it will try to reassociate, which leads to around 12 lost pings on the clients, then all is well.
But why on earth in the first place is it doing that…
Here are some logs:
Secondary (client AP):
23:58:04 wireless,debug wlan3: start background scan
23:58:10 wireless,info C4:AD:34:2E:76:27@wlan3: lost connection, no beacons received
23:58:18 caps,info CAP sent max keepalives without response
23:58:18 caps,info CAP disconnected from Main-Audience (::ffff:192.168.28.1:5246)
23:58:18 wireless,debug wlan3: must select network
23:58:18 wireless,debug 48:8F:5A:44:B2:8A: on 5560 AP: yes SSID VillaVarlyakovi caps 0x411 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-15
VHTMCS:SS1=0-9,SS2=0-9 basic 0xOFDM:6 MT: yes
23:58:18 wireless,debug C4:AD:34:2E:76:27: on 5765 AP: yes SSID SYNC-2E7627 caps 0x431 rates 0xOFDM:6-54 BW:1x-4x SGI:1x-4x HT:0-31 VHTM
CS:SS1=0-9,SS2=0-9,SS3=0-9,SS4=0-9 basic 0xOFDM:6 MT: yes
23:58:18 wireless,debug wlan3: no network that satisfies connect-list,  by default choose with strongest signal
23:58:19 wireless,info C4:AD:34:2E:76:27@wlan3 established connection on 5765000, SSID SYNC-2E7627
23:58:28 caps,info CAP selected CAPsMAN Main-Audience (::ffff:192.168.28.1:5246)
23:58:29 caps,info CAP connected to Main-Audience (::ffff:192.168.28.1:5246), CommonName 'CAPsMAN-C4AD342E7623'
23:58:29 caps,info CAP joined Main-Audience (::ffff:192.168.28.1:5246)
Primary (Main-AP):
23:58:16 wireless,info C4:AD:34:2D:BD:81@wlan3: reassociating
23:58:16 wireless,info C4:AD:34:2D:BD:81@wlan3: disconnected, ok, signal strength -50
23:58:16 wireless,info C4:AD:34:2D:BD:81@wlan3: connected, signal strength -48, wants bridge
23:58:26 caps,info [::ffff:192.168.28.10:57301,Join,[C4:AD:34:2D:BD:7D]] joined, provides radio(s): C4:AD:34:2D:BD:7F,C4:AD:34
:2D:BD:80
23:58:32 caps,info 2ghz-Secondary-Audience-1: selected channel 2452/20-Ce/gn(20dBm)
23:58:33 caps,info 5ghz-ac-Secondary-Audience-1: selected channel 5200/20-eCee/ac/P(23dBm)
23:58:49 caps,info BC:D0:74:28:E6:32@5ghz-ac-LTE-Gate-1 connected, signal strength -79
23:58:49 caps,info BC:D0:74:28:E6:32@2ghz-Main-Audience-1 disconnected, registered to other interface, signal strength -65
23:58:51 caps,info 3E:04:B8:75:F6:5A@5ghz-ac-Main-Audience-1 connected, signal strength -56
23:58:51 caps,info 3E:04:B8:75:F6:5A@2ghz-Main-Audience-1 disconnected, registered to other interface, signal strength -47
Any ideas are welcome!
check if station-roaming option is enabled on radio configuration on Client Audience
Indeed station-roaming was enabled, I’ve changed it to “disabled” and indeed the manual clearly describes that the background scan is a sub-function of station-roaming setting.
In Winbox this is only visible in “advanced settings”, should again someone wonder where do I find this.
If someone with good google-fu finds this thread in the future, here is the link to the Manual:
https://wiki.mikrotik.com/wiki/Manual:Interface/Wireless#Station-Roaming
As this config was attempted with the Push-button of the Audience (just to try it), this is the DEFAULT, which isn’t optimal…
@normis and MTik support in case you’re reading this post - maybe discuss with your Dev team to create a script and probe when there are multiple MESH devices in the config and just then enable the roaming part. If it’s a Point-to-Point WiFi, even creating the Virtual Wireless doesn’t bring any advantage IMHO.
