its no problem having a mixed dhcp and pppoe at same out interface. (if this was your question) you can have some device that get an ip via dhcp (or have a manual set ip) mixed with pppoe for authentiation. You can also have ip to CPE’s from the same pool of ip’s
my goal is to give registered customers access to gain access through hotspot authentication on any router authenticated via pppoe
this way you could control the routers connected in pppoe and give the customer the freedom to migrate between the routers without having to enter a new password in their device
