Authenticating Login Users via Radius with LDAP backend
Hi
I try to integrate the Miktrotik Routers into our central Radius AAA System. We use Freeradius with a LDAP backend.
The problem I’m facing is that when I try to log in on the web interface is that it send’s an authentication request with mschap and
freeradius seams not to be able to handle that. Is there a way to change this so that it die simple plaintext authentication?
Regards
Matthias
Webfig is MSCHAPv2.
Winbox is CHAP.
Console/SSH/Terminal is PAP.
No way to configure any of these sadly.
Why not AAA directly to MS Radius thats included with NPS?
Problem is, the LDAP is not an AD (it’s an Apache Directory Server), we do not use Windows for such things.
@Mikrotik: would it be possible to add a config option to be able to do also PAP/CHAP for Webfig ?
Regards
Matthias
Anyone got a way to set rate limit on freeradius that use LDAP on back-end?
It definatelly should be possible, but I am not good enough with Radius to tell you how.
Thanks, is there anyone on the list who has an idea about this. Basically i need a way to apply rate limit by different groups in ldap; a way to use the user profiles in hotspot to match the ldap group entries.
Anyone got an idea how i could rate-limit using freeradius with ldap backend?
