authorize.net nightmare
I’m struggling with getting the authorize.net “merchant seal” to display properly on my hotspot login page.
Authorize.net gives you a script to place on your page.
My authentication/Usermanager is on dedicated PC on it’s own IP.
My Hotspots are on separate/differerent IP’s/domains.
Before getting into details.
If I place the authorize.net javascript on a “live website” it displays properly.
But when I insert the script onto my hotspot/portal/login page it will not dispaly the “seal” properly.
I should add: The seal will display correctly on local login page. But soon thereafter it will not display the seal.
Anyone had any experience with this and been able to make the seal work properly on “local” login pages on hotspots?
