authtype mismatched error @ L2TP/IPSEC connection
Hello everyone,
I’ve tried to set up a L2TP / IPSEC connection with my Router
Mikrotik RB2011uias-2hnd-in
When i test it, i get a connection through l2tp while connected to WiFi on this same Router.
While connecting L2TP with my router my log says:
authtype mismatched: my:hmac-sha1 peer:hmac-sha256”.
At this moment i can only connect through L2TP/IPSec while connected to my routers WiFi. It should be cennecting Always even when i have no WiFi available.
When connected to mobile network say 4G only then i can’t connect (FireWall issue maybe?)
PPTP works perfect but is nog secure enough, thats why i tried to setup L2TP
Is there anyone who can help a Dutch-guy out ?
RouterOS is kind of new to me, but MikroTik inspired me to get more knowledge of how Routers work.
Best regards,
Jarno
Hi JarnoG,
Same problem here. I’ve used rOS from years ago, but never saw this error.
In my case, can’t connect using wifi connection or mobile connection. Always says: authtype mismatched: my:hmac-sha1 peer:hmac-sha256
¿Any suggestion?
Hi JarnoG,
In my case (used last rOS version, 6.32.3), can’t connect using wifi connection or mobile connection. Always says: authtype mismatched: my:hmac-sha1 peer:hmac-sha256
¿Any suggestion?
I Wish i had,
For the time being im using a pptp connection as less as neccesary. Still figuring out and trying to setup a working l2tp server.
Maybe its a bug or something like it.
Can we get some help here ?
Any update here?
I using last rOS (6.32.3) and Android 6.0 on Nexus 5 and still problem.
Mikrotik’s guys support: ¿we could help us?
Regards,
