"auto" ack behavior is that a bug or a feature in Dude 3.1
Dear forum,
since the update from 2.2 to 3.1 we expirience that services on a device
which where once ack’ed are always acked after another failure. If I
unack the alarm than I receive the notification in the usual way, also
the notification option ack => up works fine.
That disables the notification system if you have Probe Interval 1
to detect a failure.
I found a lot of new notification options but NO
Up => acked
And even if I set the probe down count to “2” I receive no notification
that the service went away?
How can I disable this auto - ack??
Thanks a lot for any hint.
Greetings,
Stephan
