Hii Everyone. I’ve installed a new Ethernet card to my 5.18 version to make a Bridge connection and as i knew it auto detect hardware but it doesn’t with this one!!
my LAN and WAN works fine but when i add this one it didn’t detected!!
what would be the reason or is there any thing i can do to install it!!
thanks.
Not all network cards are supported. Check out the HCL:
thanks for your support : )
Thnx for your support : )
Thanks for your support
thank you for your support : )
No problem ![]()
