hkd
1
Gigabit speed only be set to auto-negotiation ?
If I off the auto-negotiation and force to 1g, i cant connect to the routerboard.
Can connect with 100M with auto-negotiation off
Can’t connect with 1G with auto-negotiation off
With Auto-negotiation on, it go 1G
tested with 3 difference computer and 5 cat5,cat6 cable.
It happen on ALL PORT on RB1100ahx2 ver 5.20
Is this normal ???
dog
2
Why would you even want to disable it?
90% of times I have seen networks with major performance problems it was because someone decided it was clever to turn off auto-negotiation.
lambert
3
Maybe so he can talk to ISPs like AT&T. They force me to disable auto negotiation on my Opt-E-MAN 1GB fiber service.
hkd
4
I decide to disable the auto-negotiation
because of i have my routerboard frequently ETHERNET Link up/down on connected port.
I changed with 5 difference cable and computer.
It happen frequently every day, as i see in this forum, someone who say he can fix by turn off auto-negotiation.
That’s why i try to disable it.
janisk
5
GBit interfaces require auto-negotiation to work properly, as there are a lot more stuff that is negotiated compared to fast ethernet ports.
fibre ports are completely different story to copper.
