So I’ve seemingly made a terrible mistake. I assumed that the RAM was anything outside of the Flash folder. I had a log file outside of the Flash folder which managed to fill up the remaining memory. Now I can no longer send auto.rsc files to certain MikroTiks under my purview. I’ve been testing SSH (as we have the service enabled and the proper ports opened) and it seems to be unable to login with the information I’d use to log into WinBox. Is there some sort of default login for SSH that I don’t know about? My plan was to use an expect script to reboot all of these pieces of equipment to purge the files outside of the flash folder to allow for me to use auto.rsc files once more. Any suggestions would be greatly appreciated!
0 eleven.auto.rsc script 0 jun/07/2019 13:41:11
1 flash disk dec/31/1969 20:00:00
2 push.auto.rsc script 334 may/02/2019 21:42:42
3 push.auto.log .log file 16.0MiB may/03/2019 03:56:35
4 flash/skins directory dec/31/1969 20:00:01
5 flash/hotspot directory jan/01/1970 20:15:51
6 flash/hotspot/alogin… .html file 1293 jan/01/1970 20:15:51
7 flash/hotspot/error… .html file 898 jan/01/1970 20:15:51
8 flash/hotspot/errors… .txt file 3615 jan/01/1970 20:15:51
9 flash/hotspot/favico… .ico file 903 jan/01/1970 20:15:52
10 flash/hotspot/img directory jan/01/1970 20:15:52
11 flash/hotspot/img/lo… .png file 3925 jan/01/1970 20:15:52
12 flash/hotspot/logout… .html file 1813 jan/01/1970 20:15:52
13 flash/hotspot/lv directory jan/01/1970 20:15:52
14 flash/hotspot/lv/alo… .html file 1303 jan/01/1970 20:15:52
15 flash/hotspot/lv/err… .txt file 3810 jan/01/1970 20:15:52
16 flash/hotspot/lv/log… .html file 3408 jan/01/1970 20:15:52
17 flash/hotspot/lv/log… .html file 1843 jan/01/1970 20:15:52
18 flash/hotspot/lv/rad… .html file 1475 jan/01/1970 20:15:52
19 flash/hotspot/lv/sta… .html file 2760 jan/01/1970 20:15:52
20 flash/hotspot/md5.js .js file 7.0KiB jan/01/1970 20:15:52
21 flash/hotspot/radver… .html file 1481 jan/01/1970 20:15:52
22 flash/hotspot/redire… .html file 318 jan/01/1970 20:15:52
23 flash/hotspot/rlogin… .html file 850 jan/01/1970 20:15:52
24 flash/hotspot/status… .html file 3009 jan/01/1970 20:15:52
25 flash/hotspot/xml directory jan/01/1970 20:15:52
26 flash/hotspot/xml/WI… .xsd file 4251 jan/01/1970 20:15:52
27 flash/hotspot/xml/al… .html file 821 jan/01/1970 20:15:52
28 flash/hotspot/xml/er… .html file 416 jan/01/1970 20:15:52
29 flash/hotspot/xml/fl… .html file 361 jan/01/1970 20:15:52
30 flash/hotspot/xml/lo… .html file 787 jan/01/1970 20:15:53
31 flash/hotspot/xml/rl… .html file 530 jan/01/1970 20:15:53
32 flash/hotspot/login… .html file 804 dec/18/2018 18:09:49
33 flash/COMODORSADomai… .CRT file 2151 mar/31/2017 08:01:53
34 flash/hotspot_addmyd… .crt file 1939 mar/31/2017 08:01:53
35 flash/AddTrustExtern… .crt file 1521 mar/31/2017 08:01:53
36 flash/certificate-re… .pem file 1704 mar/28/2019 20:20:18
37 flash/COMODORSAAddTr… .CRT file 1952 mar/31/2017 08:01:53
38 flash/be258587ac15fd… .crt file 2427 mar/28/2019 20:20:17
39 flash/gd_bundle-g2-g… .crt file 4795 mar/28/2019 20:20:18
40 flash/hotspot/xml/lo… .html file 359 jan/01/1970 20:15:53
I would’ve not used copy paste if it weren’t for the lack of memory on the MikroTik.
uptime: 5w3d14h16m21s
version: 6.40.9 (bugfix)
build-time: Aug/20/2018 07:46:49
factory-software: 6.34.2
free-memory: 16.1MiB
total-memory: 64.0MiB
cpu: MIPS 74Kc V5.0
cpu-count: 1
cpu-frequency: 720MHz
cpu-load: 3%
free-hdd-space: 4220.0KiB
total-hdd-space: 16.0MiB
write-sect-since-reboot: 8052
write-sect-total: 75078
bad-blocks: 0%
architecture-name: mipsbe
board-name: hEX
platform: MikroTik
Does anyone have any suggestions? My expect script is recovering most of these but some don’t have their RSA keys (and their passwords are all different.) Which is making things difficult to recover the last few.
