auto upgrade feature
Anyone use that feature? I can’t get it to work and I don’t see anything documented on it just on some old script in the wiki, not related to this.
I upgraded a 433AH then put the npk back on that board.
On three other boards, same lan, System > Auto Upgrade > Upgrade package sources I add new and put in the ip address of the above along with a user and password. On one of those under available Packages I select refresh, it shows the npk and I can go from there manually, download all, reboot after, etc and it works. Manually
I left the others for a couple of days, nothing happens. So punting, I went back to upgrade package sources and added mirror with that same info even though it said it was ftp. Still nothing. Nothing in the logs either.
My thought was to use this feature, upgrade and re-load the npk on one of the routerboards on a particular lan then the others would auto update.
tk
Deleted because not related.
We have updated the manual: http://wiki.mikrotik.com/wiki/Manual:Upgrading_RouterOS#RouterOS_massive_auto-upgrade
Thx Normis! It is great to see updated wikis!! :slight_smile:
Sent from my DROIDX using Tapatalk 2
