I have been scouring the web for info pertaining to auto logging in users within the hotspot. I know the login.html files has to be updated but what sections of “username” & “password” need to be edited?
Thanks in advance!
-Charlie ![]()
Thanks in advance!
-Charlie ![]()
The first two examples here show what to change to use the login button without entering a username and password.
http://wiki.mikrotik.com/wiki/Manual:Customizing_Hotspot#Examples
Then you must enter that user in your database. If local, then in “/ip hotspot user”, and change “/ip hotspot user profile” shared-users entry to the maximum number of users you expect on the network.
Thanks a lot Tim. I will give this a try tomorrow. ![]()
