Automated Billing Script - Question
Hey there guys.
I’ve noticed the following in the wiki explanation:
User Manager Field Requirements
This script also requires each and every user to have the following user fields filled in:
/tool user-manager user print
  • First Name
  • Last Name
  • E-mail Address
  • Pool Name
  • Comment Field
I’m using the latest rOS (3.2) and I’m not seeing any “Comment Field” under User manager.
How will this effect my setup?
Will it still run without the comment section?? But there goes the whole “invoice number” idea now doesn’t it. Plus, now you have to configure the “usage-limit” for the user, not that there is a problem with it…
Please mr script developer sir…this is such a great script, is this the end of the script or am I just missing some thing stupid? :open_mouth:
:-p You didnt see my siggy :stuck_out_tongue: Ok i can def help you out with this and you may help me aswell, Ok You get into coment by using the /tool user-manager user edit 3 comment.. So you do a /tool user-manager user print, you will see 0 1 2 3 for there numbers, per clients they will have those attached to them, to leave a comment! I wish this was in user-manager would make it easier, I mite change the script to use the group name but as of right now i am leaving it under comment.. If you need any other help with the script I can def help you, I Know it like the back of my head NOW! Let me know because i am CURIOUS to see if this script runs on 3.2, im using rost 3. rc7 so It would be hand yto know if it works on 3.2 or 3.3. Thanks -Jordan
