Just finished ironing out what I believe are the last bugs in my usage monitoring script.
This script is handy for anyone who wants to track IP based usage each month without requiring the mikrotik user manager or radius server.
All data is stored in the queue comment field each hour so doesn’t matter if the router is rebooted, I’ve also included some simple scripts to help you generate the range of queues required.
All site details are emailed at the end of the month to client and host emails along with percentage warnings (70% 90% 100%) being sent through when limits are reached.
Example email:
Full monthly usage for CLIENT
In this month this site has downloaded 5575 MB, which is 10% of the 50 GB monthly download allowance.
Please feel free to contact me if you have any problems implementing the script.
Only known problem is that I don’t believe the queues will work correctly if you already have a queue tree setup (this uses simple queues).
This is really made for back on the AP, or back on a central router where all your traffic passes through.
It’s not made for speedlimiting (although you can do that on any queue you want) but merely to keep a record of all the traffic being used by each IP address.
It would also work fine as a secondary method of accounting to compare against radius logs.
I looked on the Wiki and found in the Talk a new version that “on peak / off peak accounting - rate limiting when over limit - adjustable on and off peak” which sounds fantastic.
I wish it was formatted though, reading through it is a little bit tricky, you’ve obviously put a lot of thought into it.
I’m looking for a script for my own RB, which has two LANS, multiple WANs/ISPs, a Primary (Specific Download Usage per Month), and others (Acceptable Usage Polices). I use Packet Marking to direct traffic over the relavent links, my local servers should use the Primary link, however to avoid going over the set Download Usage, it should warn me, and then finally direct LAN->WAN Heavy (Web) traffic via another provider at the 80% mark, and rate-limit it to ensure it’s only being used for small connection specific stuff (SMTP) for the remainder of the month.
Peak allowance is 8GB (9am to 6pm, Monday to Friday), Night is 1TB (2am to 6am every day), off-peak is 100GB (all other times). For ease of use, it should also be able to handle adding pre-paid allowance (and adding excess usage allowance, which costs more) one off for the month, and a starting “already used allowance” for current month (reset at start of next month).
It’s also very useful to get a report to identify an IP on the network that’s causing a lot of downloads, as well as generally what individual IP-based usage is.
Any chance of such a modification/new version of your script for this?
I’ll break it down into relevant sections for you to start having a look over yourself and see if I can come up with some of the code pre-done for you tomorrow (its 4:30am here )
two LANS | No problem the simple queues just go by whatever IP’s you wish to track
Multiple WANs/ISPs | Once again no prob as we’re just watching the traffic to those IP’s doesn’t matter where its going out.
Specific download usage per month | this might be a little tricky if you have set quotas on each link as regardless of which method of load balancing you use you’ll always get differences in usage. As for the users, each used can have an assigned on and off peak quota.
WAN Heavy traffic via another provider. | hmm tricky, might need a single script on one of the pppoe interfaces to help with that however for starters we can get the data monitoring up then go from there.
on-peak 8GB 9-6, Night 1TB 2-6, off-peak 100GB 6pm-2am | that can be done, mine currently works with 2 data limits but I see no major problem changing to 3.
adding pre-paid allowance | thats ok however its going to be manual (aka you edit users data and change from 10 to 20/ X to Y)
at the end of the month i’ve got mine to reset all users back to 15/15gb
Yeah, could do with “Local Time” under users details in posts.
Well, anything from those two LANs basically, the report also needs to split into the two LANs and list IPs under it for usage.
That’s because it’s only download we’re interested in, not upload right? Ok, but it’s only one ISP that has a Monthly Usage, the others are just “acceptable usage policy”, so unlimited within reason really. Hence we’re not interested in any downloads that come from those other ISPs, only the Monthly Usage one (or be able to specify your ISPs, which are metered and which are unlimited).
Using a packet mark for ISP1,ISP2,ISP3, load balancing is more directed traffic, certain LAN IPs/Ports are directed over certain ISPs. For the metered ISP1, upload is using the packet mark, it’s then split into two routing marks ISP1a and ISP1b which is then sent over either line 1 or line 2, which at the ISP1 are then put together and onto the internet. Similiarly for download, they send it down over both lines (two pppoe connections). The other ISPs are just a single pppoe, or an ethernet interface (VM cable).
For downloads from ISP1, it’s metered, with a quota a month, I’m not fussed about dividing it up internally to “users”, there’s only one user “the local network”. This is more my own monitoring and fail-safe to avoid going over the quota, then dishin it out to users internally.
I wouldn’t want the pppoe shutdown, just redirect the heavy traffic (say a big download of Windows Updates or something). Instead of packet marking it for ISP1, override and re-mark it for ISP2, but only if we’ve reached the danger zone of usage (80%).
Cool, was worried that might be complicated.
Yeah, obviously, not sure where you’d do it, smome command to write to a text file stored on the RB?
As I said before, it’s not really “users”, it’s just a single user, the local network (LANs), though an IP-based report of usage woud help identify where the bandwidth is being used on the network, ideally LAN IP, monthly amount, and itemised above a threshold, say downloads over 1MB in size, and the WAN IP (hostname would be better, but probably unlikely)
Oh and to be able to set the usage period (I believe mine is 1st - last day of Mnth, which could be 28th, 29th, 30th, 31st)
So yeah. I got busy and didn’t get around to this shame however I’m currently working on v1.5 of the script which will make the whole setup process a lot more efficient.
i have 'n problem running the script when it need to set commnd to assign a value for the :local combinedtext .
it says expected variable name (line 1 column 6)
The combinedtext value shouldn’t be modified anyway, it’s a dynamically built list of all the data usages for reporting.
You can however modify the section of email it appears in (under the relevant script)
I’ve also upgraded the script as a whole and have the new version (with improved variable handling and an easy setup procedure) listed here:
i was trying to use the latest script from the website above but had/have big problems with the emails. one thing is that i can not force the email function in ROS to NOT use TLS or to accept a self signed cert from the smtp server. if i use a server which does not support TLS i get at least something to happen. unfortunately something is still going wrong.
i had fixed a problem in the “manualusagereport”. there was this line:
:set text "$combinedtext \n $sitename: $percentage% - $megsdowncurrent MB used - Allowance is $gigs GB"
which does not work, i get an error saying: system,e-mail,error Error sending e-mail: invalid BODY
i changed that line to this:
so there is no \n for the new line in it anymore and it works.
the “monthlyreport” does send one email to the 1st queue,s email address but not to any others. i tried again to find the problem with a tcp dump but it seems the mail function in ROS or the script is mixing things up. the communication i see looks as if the script is trying to send multiple bodys in the wrong smtp session. but i can not say for sure, i am not expert in scripting on ROS at all.
if someone has this working on ROS3.30 please let me know how you got it working. here it does not work with ROS3.30 or 3.28.
ok, i found somethin strange, just for the sake of ruling out that the used smtp server is the problem i installed qmail on a system to testing. now it works perfectly fine. with the other mailserver (of our upstream provider) i get this log entry many times:
echo: e-mail,debug recv: 354-please wait\00
ROS 3.30 does not react how the mailserver would expect i wonder ?
3yz Positive Intermediate reply
The command has been accepted, but the requested action is being
held in abeyance, pending receipt of further information. The
SMTP client should send another command specifying this
information. This reply is used in command sequence groups (i.e.,
in DATA).
Used this as the basis of a bandwidth jail concept where once users have gone over there allotted daily bandwidth there queue is limited to provide better sharing of resources across all users.
I am having difficulty in trying to implement this script into the AP using OS5.6
[test@testAP] > :local content
[test@testAP] > :local i
[test@testAP] > :local sitename
[test@testAP] > :local gigs
[test@testAP] > :local email
[test@testAP] > :local megstotal
[test@testAP] > :local totalcurrent
[test@testAP] > :local bytesdowncurrent
[test@testAP] > :local bytesupcurrent
[test@testAP] > :local megsdowncurrent
[test@testAP] > :local megsupcurrent
[test@testAP] > :local percentage
[test@testAP] > :local lastwarning
[test@testAP] > :local warninglevel
[test@testAP] > :local update
[test@testAP] > :local newwarning
[test@testAP] > :local bytesdownsaved
[test@testAP] > :local bytestotal
[test@testAP] >
[test@testAP] > #Script based on Automated billing script at > http://wiki.mikrotik.com/wiki/AutomatedBill
ing
[test@testAP] > #Details:
[test@testAP] > #This script checks all current simple queues and using values stored in the queue comme
nt will allow you keep track of usage by each site
[test@testAP] > #The details stored in the queue are broken down and used to determine when a user shoul
d be sent a usage warning at 50 75 90 and 100%
[test@testAP] > #You can create/modify a new entry as long as you follow this format
[test@testAP] > #1) If you just want to name an entry you may do so like “XYZ Router” in the queue name
[test@testAP] > #2) If you want to determine a data limit, enter it like “sitename!gigabytelimit#emailad
dress!00#0000” into the comment.
[test@testAP] > #3) If you just want to enter a comment on its own, you can do this so long as you don’t
have an “!” in the field
[test@testAP] > #Breaking it down: sitename is a descriptive name, gigabyte limit is the monthy limit, e
mail address is the address you want notified
[test@testAP] > #00 is the last percentage warning level for this user, 0000 is the default value for a
new data store
[test@testAP] > #This version created by Andrew Cox - > http://www.accessplus.com.au
[test@testAP] > #v1.4 Updated 15/June/2009
[test@testAP] > :log info “------ Begining Daily Usage Reports -------”
[test@testAP] >
[test@testAP] > #For each queue in the list
[test@testAP] > :foreach i in=[/queue simple find comment !=“”] do={
{… #Pull comment out of queue and divide up accordingly
{… :set content [/queue simple get $i comment]
expected variable name (line 4 column 6)
[test@testAP] >
[test@testAP] > #Determine variables from comment
[test@testAP] > #Format is: sitename ! gigsallowed # who-to-email ! last warning level(0-50-75-90-99)
[test@testAP] > :if ([:find $content “!”] != “”) do={
syntax error (line 1 column 14)
[test@testAP] > :local pos1 [:find $content “!”]
syntax error (line 1 column 23)
[test@testAP] > :local pos4 [:len $content]
syntax error (line 1 column 22)
[test@testAP] > :local pos2 ([:find [:pick $content ($pos1+1) $pos4] “#”]+$pos1+1)
syntax error (line 1 column 31)
[test@testAP] > :local pos3 ([:find [:pick $content ($pos2+1) $pos4] “!”]+$pos2)
[test@testAP] > :set sitename [:pick $content 0 ($pos1)]
expected variable name (line 1 column 8)
[test@testAP] > :set gigs [:pick $content ($pos1+1) $pos2]
[test@testAP] > :set email [:pick $content ($pos2+1) ($pos3+1)]
[test@testAP] > :set totalcurrent [/queue simple get $i bytes]
[test@testAP] > :set lastwarning [:pick $content ($pos3+2) ($pos3+4)]
[test@testAP] > :local pos5 [:find $totalcurrent “/”]
[test@testAP] > :local pos6 [:len $totalcurrent]
[test@testAP] > :set bytesupcurrent ([:pick $totalcurrent 0 ($pos5)])
[test@testAP] > :set bytesdowncurrent ([:pick $totalcurrent ($pos5+1) $pos6])
[test@testAP] > :set megsupcurrent ($bytesupcurrent / 1048576)
[test@testAP] > :set bytesdownsaved ([:pick $content ($pos3+5) $pos4])
[test@testAP] > :set bytestotal ($bytesdowncurrent + $bytesdownsaved)
[test@testAP] > :set megsdowncurrent ($bytestotal / 1048576)
[test@testAP] >
[test@testAP] > #Begin calculating usage percentage
[test@testAP] > :set percentage ( ( $bytestotal * 100) / ($gigs * 1073741824 ) )
[test@testAP] > :log info “$sitename: $percentage%”
expected end of command (line 1 column 14)
[test@testAP] > :if ([$percentage] < 50) do={ :set warninglevel “00” }
syntax error (line 1 column 10)
[test@testAP] > :if ([$percentage] > 50) do={
[test@testAP] > :if ([$percentage] < 75) do={ :set warninglevel “50” }
syntax error (line 1 column 12)
[test@testAP] > :if ([$percentage] > 75) do={ :set warninglevel “75” }
[test@testAP] > }
[test@testAP] > :if ([$percentage] < 90) do={ :set warninglevel “75” }
[test@testAP] > :if ([$percentage] > 90) do={ :set warninglevel “90” }
[test@testAP] > }
[test@testAP] > :if ([$percentage] < 100) do={ :set warninglevel “90” }
[test@testAP] > :if ([$percentage] > 100) do={ :set warninglevel “99” }
[test@testAP] > }
[test@testAP] >
[test@testAP] > # Parse warning necessity
[test@testAP] > :if ([$warninglevel] > $lastwarning ) do={ :set warn “true” ; :set update “true” }
syntax error (line 1 column 9)
[test@testAP] > :if ([$warninglevel] = $lastwarning ) do={ :set warn “false” ; :set update “false” }
[test@testAP] > :if ([$warninglevel] < $lastwarning ) do={ :set warn “false” ; :set update “true” }
[test@testAP] >
[test@testAP] > #Update Warning Levels
[test@testAP] > :if ([$update] = true ) do={ :set newwarning $warninglevel } else={ :set newwarning $la
stwarning }
[test@testAP] > :if ([$warn] = true ) do={
[test@testAP] > #Check for email address in queue comment
[test@testAP] > :if ([$email] != “” ) do={
[test@testAP] > /tool e-mail send to=“$email” from=“> noreply@example.com> " server=“1.3.3.7” subject=”$si
tename: Usage at $percentage" body=“This message is to inform you of the current usage for $sitename
expected end of command (line 1 column 25)
[test@testAP] > The current warning trigger is $warninglevel%.
expected command name (line 1 column 1)
[test@testAP] >
[test@testAP] > This site has downloaded $megsdowncurrent MB, which is over $percentage% of the $gigs GB
[test@testAP] >
[test@testAP] > This is an Automatically generated E-mail that is sent out when users reach 50%, 75%, 90
% and 100% of their cap.
[test@testAP] >
[test@testAP] > Traffic Monitor System,
[test@testAP] > > accounts@example.com> "
[test@testAP] > }
[test@testAP] > #Send email to support/accounts also
[test@testAP] > /tool e-mail send to=”> accounts@example.com> " from=“> noreply@example.com> " server=“1.3.3.7
" subject=”$sitename: Usage at $percentage” body="Current usage for $sitename - trigger is $warninglevel%.
expected end of command (line 1 column 100)
[test@testAP] > $megsdowncurrent MB, which is over $percentage% of the $gigs GB monthly download allowan
ce.
syntax error (line 1 column 2)
[test@testAP] > Traffic Monitor System"
[test@testAP] > :log info “Sent Warning Level $warninglevel% to $email”
expected end of command (line 1 column 31)
[test@testAP] > }
[test@testAP] > #Set new warning level on queue comment
[test@testAP] > /queue simple set $i comment=“$sitename!$gigs#$email!$newwarning#$bytestotal”
syntax error (line 1 column 20)
[test@testAP] > /queue simple reset-counters $i
[test@testAP] > }
[test@testAP] > }
[test@testAP] >
As usual I must be omitting something in trying to use this script to monitor clientsusage on a AP with static IP’s (10.100.50.x) using pppoe server on the AP.
You can’t just paste scripts into the CLI. The scope is different. Either surround the whole script with a pair of matching brackets (‘{ }’), or paste the script content into an actual script object in “/system script” and execute it from there.
Quick trick to generate queues #change the target address range to match what you want to generate.
:local x
:for x from 2 to 254 do={/queue simple add target-address=“10.2.100.$x” queue=“default/default”}
would generate queues for 10.0.0.2-10.0.0.254 for you.
How do i modify this to pppoe clients on a 10.100.50.x pool
Not to be disparaging or mean, but if you understand the script that little (and what you asked is a very, very, very fundamental thing) I don’t think it’s a good idea to run it. Applying configuration you don’t actually understand to your router is asking for trouble. What do you do when a paying customer reports an issue? You can’t even troubleshoot it because you can’t be sure what the routing is doing.
Yes I agree i do have very little knowledge of scripts but I am using a test AP to configure this and teach myself and there is no customers connected and when it’s working i can transfer to a active AP and plan B is if issues occur then, from my backup’s is to roll back to config before this,
