Hello
If i have a config backup file of a RB750 device and that devices is damaged, is it possible to restore that backup to the new RB750 device( exatly the same model)
No. It is not suggested. You might encounter strange problems that only netinstall can repair after that. Use exported configuration script and import it if necessary.
Thanks.
what about if I import the exported configurations to the new device. Is it ppssible to encounter problems.
do u mean that it is better to configure the new device instead of import or restoring?
It is always better to make a new configuration manually starting from blank config. Your old export can guide you and you can use it for copy and paste of its parts. Unfortunately even with removed config some defaults stays there…
