Automatic change in queues
hi
I have made diffrenet-2 profile having various speed and wot i wans to do
for a particular timing current queues change to double of that and again particular time finish it come to previous.I had done that work indivisualy but its not possible to do for numbers of logins, is there any simple method to do that.
something like:
/queue tree set [/queue tree find max-limit=512000] limit-at=256000 max-limit-256000
it will change all queues with max-limit set to 512000 to 256000
Thanks a lot ASM, It was that i wans
How do i limit in days,
I mean i have clients of 100 hours and 3 month validity, Then how i limit that user will be kicked out after three month from the date of first login
Maybe give a try to HotSpot manager?
http://www.mikrotik.com/hotspot.html
