Automatic client login to hotspot !!!
Dear all,
I’m connected to my ISP via Mikrotik wireless hotspot.
Everytime I connected to internet, I must open my web browser and login thru the login page. Then I can use email client and so on.
Is there any way to bypass this login page?
Any script or program I can add to Windows startup so I don’t need to login manually? Without any changes to the server side.
Fyi, my ISP is using default Mikrotik/ROS login page.
Thanks.
You can use “login-by=cookie,http-chap”, and a cookie will log you in without a login page, but you must have NTP set or the cookie will timeout each time you close your web browser.
edit: That change must be made on the router that has the hotspot, so your ISP would need to implement that.
