Automatic default route change
Whenever LAN_1 is enabled, dynamic routing uses the LAN connection instead of WAN (Route list) and cant find route to internet.
Please help.
There’s no “dynamic routing”, the reason why it happens is that 192.168.1.1 (the gateway IP) fits both into 192.168.1.0/24 (the WAN subnet) and 192.168.1.0/25 (the LAN1 subnet), and if both interfaces are up, RouterOS probably throws a coin to choose. But such a setup with overlapping subnets attached to different interfaces will cause more trouble than just this one.
So you could configure the default route indicating both IP address and interface as gateway (192.168.1.1%WAN), but doing so would not resolve the other issues.
What are your reasons to have the two halves of the WAN subnet assigned as LAN1 and LAN2 subnets?
Thanks, I didn’t think about that.
