I’ve got two ideas:
Seraching for rules witch haven’t got mac address and getting it from ARP.
For each item in ARP check ip and compare it with firewall rule.
I’ve got two ideas:
I’ve got list of IP’s without MAC address:
:foreach i in=[/ip firewall dst-nat find src-mac-address=00:00:00:00:00:00 ] do={
:put [/ip firewall dst-nat get $i src-address]
But how can I convert it, ex.
192.168.0.222/32 → 192.168.0.222
at this moment you can’t do it. There is no possibility to work with strings currently.
Edgars
I think that this would be good
:global x
:global y
:foreach i in=[/ip arp find dynamic=yes ] do={
:set x [/ip arp get $i address ]
:set y [/ip arp get $i mac-address ]
:if([/ip firewall dst-nat find src-mac-address=00:00:00:00:00:00 src-address=$x ] != 0) do{
:put ($x . " → " . $y)
/ip firewall dst-nat set [/ip firewall dst-nat find src-mac-address=00:00:00:00:00:00 src-address=$x ] src-mac-address=$y
:if([/ip firewall rule forward find src-mac-address=00:00:00:00:00:00 src-address=$x ] != 0) do{
/ip firewall rule forward set [/ip firewall rule forward find src-mac-address=00:00:00:00:00:00 src-address=$x ] src-mac-address=$y
:unset x
:global y
‘:put’ command will not display anything on the screen if you write it in the script.
Edgars
