Is there any way to automatically log in through SSH (From either a windows box or say FreeBSD)?
I thought about using public/private keys but i dont see them mentioned, can certificates work? I really need this to make an automated system to apply for example firewall corrections or gather certain system information.
you can try secureblackbox components, i think.
In the manaul, I think there is a reference to putty’s utility that executes commands for you.
John
What im most concerned with is the automatic login procedure, pointers?
Expect works well, you just need to learn TCL.
–Eric
Sten,
I think I know what you mean. I have the same question.
You want to have automatic ssh logins, without having to type in a password, by just exchanging keys once.
In linux, I would create on the box I want to login to (ala LInux Server Hacks by Flickenger)
ssh server “mkdir .ssh; chmod 0700 .ssh”
scp .ssh/id_rsa.pub server:.ssh/authorized_keys
I think I’m paraphrasing your question when I ask:
“Can you use public keys to login to a Mikrotik box via ssh instead of passwords?”
Erik
[quote=“erikturk”]Sten,
Erik[/quote]
I had the same problem. Commands like ‘ssh -l user command’ don’t work even after entering a password manually. I asked the guys from MikroTik and they told me, that this feature is not implemented yet, and promised to fix this problem in 2.9 version. While waiting for stable v.2.9, I wrote a simple software, that runs a script in a telnet session.
Vadim
