Is there anyway to get the RouterOS to automatically reboot daily? We have them installed on all our sites operating as a hotspot - a daily reboot seems to clear any problems we have. If I could set them to reboot automatically at 0300 for example, that would excellent.
Hi, since this thread has went this way like it or not if your customer has a lot of connections and you’re saving in hardware, it is better to reboot it daily. Sometimes the board seems unusable. Recently I installed one and the customer almost threw it out because of this problem. All I had to do was create this script and voila problem solved! no more complaints. I had to do this because I could not find what the actual problem is, unfortunately
