Automatic wirelles uplink RBWAPG 5HACT2HND
Hi All,
I´m new in the “world of Mikrotik” … I´ve done a lot with ubiquiti …
So my problem is:
I have 3 x RBWAPG 5HACT2HND > the Wlan is only for 3 clients “only” 2.4 GHz
1 x RBWAPG 5HACT2HND is to be installed as Master with CapsMan and connected by network cable
2 x RBWAPG 5HACT2HND should be configured to allow
  • if connected via network cable via WAN Port > controlled by CapsMan and work as access points 2.4GHz
  • if power on without a WAN port or a WAN port failure or disconnect on WAN port > connect automaticly wireless to the master via 5GHz WLAN and managed by CapsMan > and work as access points 2.4GHz
How can I get a solution for that ?
Thanks for your help !
