automatically added networks
Anyone know how to make the dude stop auto-adding Networks? I get a bunch of dif’t 10.0.1.0 networks even though I only have one! Is it because my RB1200 has several dif’t devices all on that network? I disabled all the auto add features I could find in the Dude but they keep getting added!
On the general tab of a map settings you can find Auto Scan: and a list of networks that you are automatically scanning, opening a network that you scan will give you “Discover Info” if that check mark for “add Networks” is not checked and it is still adding networks then I don’t know what else you could try besides un-checking other things that add network structure.
HTH,
Lebowski
