automatically switch between sims card based on speed test
I have a MikroTik LtAP Mini LTE Router Dual SIM, i would like to use a default sim card, however in the event that the networks speeds drops below a certain threshold (i.e ping response time is > X) i would like to swop to the second sim card. The intent is to use the router in an application which requires an always on internet connection.
Please advise if this is possible?
I have been through the dual sim wiki (https://wiki.mikrotik.com/wiki/Dual_SIM_Application) though this checks the roaming status and not any ping response time.
Many thanks in advance
Good day friend, if possible. you just have to mark the traffic and monitor both lines. and change your default route at the time you have the preconfigured events.
