Automating CPE ROS/Firmware/script changes - Updated
As your network grows, you will find that updating ROS versions and Firmware versions and scripts on CPE’s becomes a time consuming process. By following the process below you will only have to manually access your existing client units one last time, to load the scripts below. Once the CPE’s are loaded with the scripts they will automatically update their ROS versions and Firmwares when you trigger the scripts by turning on the relevant IP’s that the CPE netwatch routines will detect and run the update scripts. You manually control when this happens.
  1. At a central point, a Mikrotik AP or Edge/Gateway Router - this where you place upgrade script file and ROS update files in future.
Create IP addresses (a unique subnet) on an ethernet port as per the example below. These IP’s do not have to be on a dedicated ethernet port,as Mikrotik allows creation multiple IP’s/subnets on a single interface. Please note that these IP address’s are disabled. They are only enabled when you wish to trigger the update routines on the CPE’s.
add address=172.16.0.1/24 comment="CPE File Upgrade" disabled=yes interface=ether1 network=172.16.0.0
add address=172.16.0.2/24 comment="RouterOS Upgrade" disabled=yes interface=ether1 network=172.16.0.0
add address=172.16.0.3/24 comment="Firmware Upgrade" disabled=yes interface=ether1 network=172.16.0.0
add address=172.16.0.4/24 comment="Force CPE Reboot" disabled=yes interface=ether1 network=172.16.0.0
That is all the scripting you will be required to do on the edge/gateway-router/AP. You will need to ensure that your network routing tables at each AP, know where to find the IP subnet created above, so the CPE’s Netwatch routines you will soon create, will know where to find the trigger IP’s.
On Each CPE:
  1. Now we create to script that fetches the client unit upgrade file (always called upgrade.rsc, unless you change it in the script below).
The “Upgrade Script” to be installed on all your CPE’s:
/system script
add name=rscfetch policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api source="{\r\
    \n:global ftpserver\r\
    \n:global usrnme\r\
    \n:global passwd\r\
    \n:global pckgname\r\
    \n\r\
    \n:set pckgname (\"upgrade.rsc\")\r\
    \n###########################################\r\
    \n# Set the package name above as you wish. Remember that your upgrade file (NOT the ROS files) must in future, have the same name as what you set here.\r\
    \n# Set the IP below, to exactly the same as the trigger IP you added with the comment "CPE File Upgrade" in step 1.\r\
    \n# Replace "admin" and "password" below with the correct settings to allow ftp access to the server.\r\
    \n:set ftpserver \"172.16.0.1\"\r\
    \n:set usrnme \"admin\"\r\
    \n:set passwd \"password\"\r\
    \n\r\
    \n:if ([:len [/file find name=\"upgrade\"]] = 0) do={:log error \"Downloading Upgrade File - \$pckgname\";/tool fetch address=\"\$ftpserver\" src-path=\"\$pckgname\" user=\"\$usrnme\"
password=\"\$passwd\" mode=ftp;/import upgrade.rsc} else={:log error \"No Upgrade File Found\";}\r\
    \n}"
  1. Now add a netwatch routine to the CPE to trigger the script to fetch and load the upgrade.rsc file.
/tool netwatch
add disabled=no down-script="" host=172.16.0.1 interval=1m timeout=1s up-script=rscfetch;
  1. Add the source for future ROS upgrades. In our case we use the same IP as the trigger IP set in step 1 with the comment "“RouterOS Upgrade”. You will be prompted for the password when you add this, it cannot be coded into the script.
/system upgrade upgrade-package-source
add address=172.16.0.2 user=admin
  1. Summing up the required CPE scripts above, you can edit and load the following onto each CPE in one routine (cut and paste to a terminal window)
Summary CPE Code
/system script
    \n:global usrnme\r\
    \n:global passwd\r\
    \n\r\
    \n\r\
    \n}"
/tool netwatch
add address=172.16.0.2 user=admin;
Remember to add the password for the upgrade source when prompted at the end of the routine.
Only once ALL CPE’s are update with scripts from Step 2 to Step 4 or via the Summary Code in Step 5, proceed to Step 6.
  1. Now we can create an upgrade.rsc file (or whatever name you designated as $pckgnme above), to load to 172.16.0.1
File upgrade.rsc below, assumes the IP triggers set in Step 1 are correctly referenced below.
:if ([file find type=".rif file"]!="") do={/file remove [find type=".rif file"]}
:if ([file find type=".tar file"]!="") do={/file remove [find type=".tar file"]}
:if ([file find type="backup"]!="") do={/file remove [find type="backup"]}
:if ([file find type="script"]!="") do={/file remove [find type="script"]}
/system backup save;
:delay 10s;
/system script
:if ([find name="upgrade"]!="") do={remove [find name="upgrade"]}
add name=upgrade policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="{\r\
    \n:global NewV\r\
    \n\r\
    \n/system upgrade refresh;\r\
    \n\r\
    \n:delay 30s;\r\
    \n:set NewV [/system upgrade get [/system upgrade find name=\"routeros-mipsbe\"] version]\r\
    \n\r\
    \n:set pckgname (\"routeros-mipsbe-\". \$NewV . \".npk\")\r\
    \n:set ntpname (\"ntp-\". \$NewV . \"-mipsbe.npk\")\r\
    \n\r\
    \n:if ([/system upgrade get [/system upgrade find name=\"routeros-mipsbe\"] status]!=\"installed\") do={/system backup save;:log error \"Downloading Latest Version file - \$pckgname\";/system
upgrade d\
    ownload [/system upgrade find name=\"routeros-mipsbe\"];} else={:log error \"Latest Version file - \$pckgname already installed\";}\r\
    \n\r\
    \n}\r\
    \n\r\
    \n"
:if ([find name="upgradefirm"]!="") do={remove [find name="upgradefirm"]}
add name=upgradefirm policy=\
    ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api \
    source="{\r\
    \n:global oldfirm [/system routerboard get current-firmware];\r\
    \n:global newfirm [/system routerboard get upgrade-firmware];\r\
    \n:if ([\$oldfirm]<[\$newfirm]) do={:if ([/tool netwatch get [find host=\"172.16.0.4\"] disabled]=yes) do={/tool netwatch set [find host=\"172.16.0.4\"] disabled=no;}}\
    \r\
    \n\r\
    \n:if ([\$oldfirm]<[\$newfirm]) do={/system routerboard upgrade;}\r\
    \n}\r\
    \n"
:if ([find name="rebooting"]!="") do={remove [find name="rebooting"]}
add name=rebooting policy=ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive,api source=\
    ":if ([/tool netwatch get [find host=\"172.16.0.4\"] disabled]=no) do={/tool netwatch set [find host=\"172.16.0.4\"] disabled=yes;}\r\
    \n:delay 20s;\r\
    \n/system reboot;\r\
    \n"
/tool netwatch
:if ([find host="172.16.0.2"]!="") do={remove [find host="172.16.0.2"]}
:if ([find host="172.16.0.3"]!="") do={remove [find host="172.16.0.3"]}
:if ([find host="172.16.0.4"]!="") do={remove [find host="172.16.0.4"]}
:if ([find host="172.16.0.2"]="") do={add disabled=no down-script="" host=172.16.0.2 interval=1m timeout=1s up-script=upgrade}
:if ([find host="172.16.0.3"]="") do={add disabled=no down-script="" host=172.16.0.3 interval=1m timeout=1s up-script=upgradefirm}
:if ([find host="172.16.0.4"]="") do={add disabled=yes down-script="" host=172.16.0.4 interval=1m timeout=1s up-script=rebooting}
For explanation purposes, we have the upgrade.rsc code explained in detail below.
The first part of the script clears certain file types to ensure that the CPE’s do not become congested with numerous files, and it then makes a backup of the CPE’s configuration.
:delay 10s;
The next section loads scripts onto the CPE. The first script is to upgrade the ROS on the CPE. This does not need to be editted, as it runs via the system upgrade resource function. This is triggered by enabling 172.16.0.2 as set in Step 1.
/system script
    \n:global NewV\r\
    \n\r\
    \n\r\
    \n:delay 30s;\r\
    \n\r\
    \n\r\
upgrade d\
    \n\r\
    \n}\r\
    \n\r\
    \n"
The next 2 Scripts to be added to the CPE control the Firmware upgrade and reboot. It is suggested that these two only be triggered AFTER a ROS upgrade, as very often the firmware only changes once a ROS upgrade is carried out. These is triggered by enabling 172.16.0.3 and 172.16.0.4 as set in Step 1. The firmware upgrade script compares the current version with the new version, and updates if a difference exists. If a difference in versions exists it also turns on the netwatch to set a reboot in motion.
    source="{\r\
    \r\
    \n\r\
    \n}\r\
    \n"
    \n:delay 20s;\r\
    \n"
Finally we add the additional netwatches required to trigger the various routines on the CPE.The script tests if the netwatch hosts already exist, if so, deletes them, and then adds new netwatch routines.
/tool netwatch
To make additions to CPE scripts, upgrade ROS versions, adjust firmware versions, add upgrade.rsc and the ROS package file to the files on 172.16.0.1. The enable IP addresses 172.16.0.x, depending on what you want to upgrade. To simply change settings/add scripts etc on a CPE, enable 172.16.0.1. For ROS upgrades, enable 172.16.0.2. To do a firmware upgrade, enable 172.16.0.3 AND 172.16.0.4.
Always test the upgrade.rsc script on a single CPE before activating the network wide IP trigger. To do this, log into a CPE, and /system script run rscfetch and observe the outcome. Obviously this will be safest on a CPE that is physically nearby you, in case you accdientally shut down a WLAN interface or disable something requiring you to reset the CPE.
This has been tested and works on ROS V5.20.
This might be useful to the less skilled operators who need to simplify adjusting items on their Client Units.
Cheers
Brian
Zimbabwe
Edit: 20 August 2012 - Tested on ROSv5.20 and working
Edit: 20 August 2012 - This post now incorporated in thread lead post.
This is a very good set of scripts.
Any chance of making them into a wiki page?
This thread now in the Mikrotik Wiki at Semi-Auto…
