Hello everyone,
Was wondering if anyone might be looking for a little tool to perform some actions on mikrotik units.
The tool is extremely rudimentary at the current point in time, but I am open to suggestions from any of the devs/programmers within the community.
Apologies if this is in the wrong section, not too sure where to share information like this.
Hope this can help somebody out there to save some time or maybe give an idea that can be taken further.
PS: I am only a python hobbyist so apologies for the non-pythonic coding ^^
Link is at: https://github.com/4rt-Net/Mikrotik-Automation/blob/main/SwissTik.py
Code is as follows:
import argparse
import paramiko
import re
import time
from time import sleep
parser = argparse.ArgumentParser(description='\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Created by Art-Net ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~\n\nThe lazy-admin tool to quickly and easily perform functions on RouterOS.\nSpecifically created to save you time and sanity while changing settings remotely.\n\nThis tool uses SSH to open a connection to the target\nDue to SSH being used this tool is sensitive to ssh configuration:\nrequirements: port 22 needs to be open on RouterOS\n\n~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~', formatter_class=argparse.RawTextHelpFormatter)
parser.add_argument(
"--command",
"-c",
default="None",
help=(
"List of commands:\n"
" check-mac\n"
" check-identity\n"
" check-scanlist\n"
" change-radioname\n"
" create-ssl\n"
"--username",
"-u",
default="admin",
help="specify username for login"
"--password",
"-p",
default="None",
help="specify password for login"
"--target",
"-t",
default="0.0.0.0",
help="specify IP address to target"
"--ssl",
"-s",
default="Cert-1",
help="Specify name for ssl certificate"
"--radioname",
"-r",
default="None",
help="specify radio-name for wlan1 interface"
def MacRegex():
macregex = "([0-9a-fA-F]{2}:){5}[1-9a-fA-F]{2}"
file = open('temp-maccheck.txt', 'r')
for lines in file:
matches = re.search(macregex, lines)
if matches != None:
print(matches.group())
def ScanlistRegex():
scanregex = "scan-list=\d{4}-\d{4}"
file = open('temp-scanlist.txt', 'r')
for lines in file:
matches = re.search(scanregex, lines)
if matches != None:
def main(args):
#Check mac address of wlan1 interface
if args.command == "check-mac":
try:
client = paramiko.SSHClient()
client.set_missing_host_key_policy(paramiko.AutoAddPolicy)
client.connect(hostname = args.target , port='22', username= args.username ,password= args.password ,look_for_keys=False)
print("Connected to: "+(args.target))
stdin,stdout,stderr = client.exec_command('/interface wireless print')
output_read = stdout.readlines()
file=open('temp-maccheck.txt','w')
file.write(''.join(output_read))
file.close()
stdin,stdout,stderr.flush()
except:
print("# Connection failed to: ", args.target)
print("check that the port 22 is open on the target")
finally:
client.close()
MacRegex()
#Check scanlist of unit
elif args.command == "check-scanlist":
try:
file=open('temp-scanlist.txt', 'w')
file.close()
except:
finally:
client.close()
ScanlistRegex()
#Check system identity of unit
elif args.command == "check-identity":
try:
stdin,stdout,stderr = client.exec_command('/system identity print')
print(output_read)
except:
finally:
client.close()
elif args.command == "change-radioname":
try:
stdin,stdout,stderr = client.exec_command('/interface wireless set wlan1 radio-name='+str(args.radioname))
print("Unit is reconnecting, radio-name changed to:"+str(args.radioname))
print("closing ssh connection...")
client.close()
except:
elif args.command == "create-ssl":
try:
print("Creating SSL Certificate...")
stdin,stdout,stderr = client.exec_command('/certificate add name='+(args.ssl)+' common-name='+(args.ssl)+' key-usage=key-cert-sign,crl-sign key-size=2048 trusted=yes days-valid=1175')
print("Done")
stdin,stdout,stderr = client.exec_command(('/certificate sign '+(args.ssl)+' name='+(args.ssl)+' ca-crl-host='+(args.target)))
print("Signing certificate, please wait...")
time.sleep(20)
print("Done")
print("Assigning certificate to API-SSL service...")
stdin,stdout,stderr = client.exec_command('/ip service set api-ssl certificate='+(args.ssl))
print("SSL Certificate completed!")
client.close()
except:
if __name__ == "__main__":
main(parser.parse_args())
