Therefore I configured my edge router to hold the firmware files within a subdirectory of my USB:
For the connection to this router I have added a separate account with read-only permission/group.
Then on the remote sites I have set up the auto upgrade sources:
nothing happens, only the login on the edge router via winbox is logged.
When running
/system/upgrade/download-all
failure: don't know which is system package
this error appears.
Does anyone have an idea on what I am doing wrong? this feature is not pretty much documented but in my case very helpful. It was absolutely annoying to configure/enable internet access for my management network each time i want to drive updates.
When upgrading by using “check-for-updates”, all versions earlier than 7.12 will display 7.12 as the latest available version. Upgrade from v7.12 to v7.13 or later versions must be done through 7.12 in order to convert wireless packages automatically. Fresh installation with Netinstall or manual package installation works in the same manner as always
IMO this is very likely. You may want to open issue with MT support asking them to provide detailed description (or example of setup) of this function.
So I’ve finally tried moving the .npk files to the root directory and it still does not work
The main router shows user mirror logged in from via winbox
And then nothing happens and finally a logout message is displayed.
On the client’s side there are either no messages logged, even when enabling the debug topic within the logger
Maybe anyone here who got this working?
Additionally i don’t understand what the “Mirror” submenu is exactly for
