Hi. Today I had some problems with my LTE signal (RSRP). Anyway It’s solved, but I have me a doubt because when I disconnect the U.FL connectors from R11e-LTE card, I see that the first “port/connector” says “AUX” and the second “MAIN”. If I connect only the AUX, it connects only with 3G but never I have Internet connection, then, if I connect the MAIN, “magically” Internet works, and then if I disconnect again the AUX port, nothing happends, all normal.
My question is: What is the purpose of the AUX connector?
I know it. My question is what is the porpuse of the aux connector. I researched on Internet and some people says that improve the speed (download or upload, I can’t remember right now), but in my tests I no see differences (40 Mbps DL / 10 Mbps UL).
Would be great that someone can confirm this or if know something different.
Sorry to be Captain Obvious but the purpose of the aux connector is to connect second chain of LTE MIMO antenna to your routerboard, literally
So I reckon the real question would be why use MIMO antenna in the first place, and the answer to that is to have more speed, if you lucky enough to have support from your carrier, and current cell tower have aggregation enabled, and your modem uses all the supported bands etc etc
Carrier aggregation has nothing to do with MIMO … CA would be if WiFi would alliw simultaneous use of both 2.4 and 5GHz WiFi bands … in a much more sleek way than some link bonding …
BTW, basic standard for LTE requires use of MIMO 2x2 … hence every LTE device uses at least 2 antennae. Both are equally important thus naming main/aux is unfortunate. Usual designation is to number ports from 0 upwards.
LTE does not require MIMO, it can run with SISO, so how does one know what transmission mode the modem is using, and if the modem you have can do MIMO?
