Hi! I searched around, but so far I couldn’t find a real solution for my problem. I use a AVM Fritz!Box 7050 as some ATA behind a 532A Mikrotik Router which does the PPPoE and NAT. So far I succeeded that I can make outgoing calls, but incoming works sporadically only and mostly for a limited time - typically 30 seconds.
I don’t really like port forwarding as maybe there will be more than one ATA behind the NAT gateway sooner or later. Is STUN a possible solution? I have the feeling that is works with “Sipgate.de” but not with “1&1”. Any experiences?
SIP and NAT go together like cats and water. It just hates it.
STUN would be a good solution, depending on your service.
I know that the SPA2002/PAP2 work very well on our VoIP solution (this is one small occurrence of SIP and NAT cooperating =). We have dozens of them behind a single public IP and many in residential deployment.
I’m told that Vonage and Packet8 work behind NAT, but I do not have any experience. I know that Vonage uses the SPA2002/PAP2 devices but I’ve no idea where Packet8 comes into play technology wise.
Thanks! I noticed SIP and NAT don’t like eachother. Hmm… I have been experimenting for quite a while and found strange effects. Even though I’m using STUN sometimes audio goes in one direction only… I also tried port forwarding and it works with mobile phones but not with landlines… sigh I’m running out of ideas.
I read that the new Mikrotik OS 3 will have a better support of SIP but I cannot update my router as its mounted on a roof of a company where I can only access in emergency… I don’t dare to update it remotely as maybe it might lose its config thus locking me out of any further access as it’s a wireless connection only…
Is there a cookbook how to make a Mikrotik 2.9.46 aware of SIP traffic and forward it correctly? I really need this ATA to work soon. It’s ok if I need to have ports opened as long as it works…
Thanks. I have been experimenting with the sip helper (v3.0rc13) but I don’t know what it does exactly? Do I need to enter the SIP ports that are needed for my ATA device or does it find out automatically? Even though I tried I couldn’t get a reliable connection to my telephony provider yet, it’s very frustrating. Is there a way to monitor the sip helper perhaps?
I also would like to try forwarding specific ports to my ATA device manually too, but how can I achieve this as my ISP IP address is dynamic only. Thus I cannot simply enter a dstnat rule as it demands a static address (correct?) or is there another way to achieve this?
