I just bought a mANTBox ax 15s to replace a mANTBox ac 15s, but I am facing a difficulty. Below I detail what happens. I was using the mANTBox ac 15s as a CPE to my ISP, and within it I had an established configuration where wlan1 (the physical wireless interface) and 3 more virtual interfaces that used wlan1 as the master interface each act as a CPE to the ISP. (uses the 802.11A/N standard, without proprietary protocols), each receiving IP to its DHCP-Client and implementing a PBR technique. When upgrading to the mANTBox ax 15s (which already comes with the qcom wifi package by default), I encounter the problem that, when creating the virtual wifi interfaces and using the wifi as the master interface, they do not connect in Station mode to the ISP and therefore, their DHCP-Client does not receive IP, but the wifi1 interface (the physical wireless interface), if it connects to the ISP, its DHCP-Client receives IP and the PBR works through that Interface.
The wifi1 interface when connecting appears as:
RMB
R - Running
M - Master
B - Bound
The virtual interfaces wifi2 to wifi4 appear as:
B
B - Bound
I have looked in the Mikrotik documentation for information about whether there is any incompatibility of the wifi-qcom package with creating virtual interfaces in station mode, and it seems there should be no problem. I hope it can help figure out why those virtual interfaces don’t connect, but the physical interface does.
