You do not specify what is unstable, what behavior do you see which is unexpected, how did you configure your devices, …
As of 7.10 (beta, stable and rc version) I have not seen any wifi problems on home AX2/3 (standalone) nor work AX3/cap AX devices (under capsman control).
Did you use 7.11 or is 7.10 the last one? With 7.11 I got some „hardware resets“ resulting DFS Scan …. With 7.12beta1 I have sporadic „SA query timeout“ with -61 dbm signal …
I used at home pretty much all beta and rc versions of whatever 7.x release.
Currently 7.11. Didn’t have time yet to install latest beta before leaving for holidays.
We could play blind man’s buff game if you wish but:
Yes … not focused on it … but it does not matter if not enough and proper info was in the whole original post.
Which device CAPSMAN is installed on? Maybe moving to other one could help .. could be a problem. Who knows?
No …
Are you sure? Are these devices connected directly? Via other device? Do they stable “see” each other at L2 level? Maybe it makes the difference what devices they are connected to … just asking as we do not know LAN topology
What means " Tried 7.11. Has hardvare resets events"? Which one? Both? When?
What means “unstable”? Lost connectivity at all? Slow connections? Drops? Please elaborate
The more details the better answer could be. It’s you waiting for help so why not to help others to help you?
It’s feature that “steers” client devices to more capable wireless network, for eg, in dual band APs, when client connects to AP, AP checks is this client dual band capable, and if it is, it “steers” client to connect to 5GHz radio where it can achieve better speeds and leaves 2.4 GHz spectrum for slower devices.
That way you don’t congest 2.4 GHz network even more and your more capable devices are connected to faster network
