AX2 Reset
Can someone please tells me the reset procedure? I tried power off , press the reset button keep it pressed while power on. The router reacts in different ways
  • I see the blue light flashing slowly
  • sometimes the green light start to flash
but all does not get the default config back to the system.
Reset button manual: https://help.mikrotik.com/docs/display/ROS/Reset+Button
I tried all possibilities but can’t get the router in default configuration.
There is nothing on the wire, link comes up (blue light flash once) and the link does down again. The times seems to be always different.
