Hi all,
I have successfully set up a guest network and all is working well, however whenever I try to add a simple queue to limit traffic on the guest network the queue shows up but doesn’t work. I’m sure I am missing something fairly simple but I’m not sure what exactly.
I’ve included the config which doesn’t have the queue. I’m hoping someone maybe be able to add it and explain the process.
Thanks.
BTW… Yes there are 3 WANs in the config and they seem to work fine independent of each other. We housesit a lot and often in places where the internet is shocking or the owner’s modem isn’t up to par. So having 3 WANs is easy for us to plug and play regardless of the owner’s provider.
# 2025-05-30 18:01:05 by RouterOS 7.19.1
add admin-mac=xx:xx.xx:xx:xx:xx auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
set [ find default-name=ether1 ] comment=WAN-LTE
set [ find default-name=ether2 ] comment=WAN-DHCP
set [ find default-name=ether3 ] comment=WAN-PPPoE
set [ find default-name=ether4 ] comment=LAN
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=all \
.width=20/40/80mhz comment="5G AX" configuration.country="New Zealand" \
.mode=ap .ssid=NeverUMind disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk .encryption=ccmp .passphrase=xxxx
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz comment="2.4G AX" configuration.mode=ap .ssid=\
NeverUMind disabled=no security.authentication-types=wpa2-psk,wpa3-psk \
/interface vlan
add interface=ether2 name=DHCP_v10 vlan-id=10 use-service-tag=yes
add interface=ether3 name=vlan10 vlan-id=10 use-service-tag=yes
/interface wifi
add configuration.mode=ap .ssid=NeverUMind-IoT datapath.client-isolation=yes \
disabled=no mac-address=xx:xx:xx:xx:xx:xx master-interface=wifi2 name=\
2.4G-IoT security.authentication-types=wpa2-psk .encryption=ccmp \
.passphrase=xxxx
add configuration.mode=ap .ssid=NeverUMind-Guest datapath.client-isolation=\
yes disabled=no mac-address=xx:xx:xx:xx:xx:xx master-interface=wifi2 \
name=2G-Guest security.authentication-types=wpa2-psk,wpa3-psk \
.encryption=ccmp .passphrase=xxxxx
yes disabled=no mac-address=xx:xx:xx:xx:xx:xx master-interface=wifi1 \
name=5G-Guest security.authentication-types=wpa2-psk,wpa3-psk \
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan10 name=pppoe-1 password=\
password use-peer-dns=yes user=username
add comment=defconf name=WAN
add comment=defconf name=LAN
add name=default-dhcp ranges=192.168.88.10-192.168.88.254 comment=Main
add name=dhcp_pool1 ranges=10.10.10.2-10.10.10.254 comment=IoT
add name=dhcp_pool2 ranges=10.10.20.2-10.10.20.254 comment=Guest
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add address-pool=dhcp_pool1 interface=2.4G-IoT lease-time=10m name=dhcp1
add address-pool=dhcp_pool2 interface=2G-Guest lease-time=10m name=dhcp2
add address-pool=dhcp_pool3 interface=5G-Guest lease-time=10m name=dhcp3
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
/ipv6 settings
set max-neighbor-entries=15360
add interface=pppoe-1 list=WAN
add interface=DHCP_v10 list=WAN
/interface ovpn-server server
add mac-address=xx:xx:xx:xx:xx:xx name=ovpn-server1
192.168.88.0
add address=10.10.10.1/24 interface=2.4G-IoT network=10.10.10.0
add address=10.10.20.1/24 interface=5G-Guest network=10.10.20.0
add address=10.10.20.1/24 interface=2G-Guest network=10.10.20.0
/ip dhcp-client
# Interface not active
add address=10.10.10.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.10.10.1
add address=10.10.20.0/24 dns-server=1.1.1.1,1.0.0.1 gateway=10.10.20.1
192.168.88.1
set allow-remote-requests=yes
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan type=A
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=drop chain=forward in-interface=2.4G-IoT out-interface=bridge
add action=drop chain=forward in-interface=2G-Guest out-interface=bridge
add action=drop chain=forward in-interface=5G-Guest out-interface=bridge
/ip ipsec profile
/ip service
set ftp disabled=yes
set telnet disabled=yes
set www disabled=yes
set ssh port=2206
set api disabled=yes
set api-ssl disabled=yes
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/system clock
set time-zone-name=Pacific/Auckland
/system identity
set name="Home Router AX"
/system ntp client
set enabled=yes
/system ntp server
set broadcast=yes enabled=yes manycast=yes multicast=yes
/system ntp client servers
add address=time.cloudflare.com
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes
