Two questions please:
How can I confirm that the config below matches what would on this forum be labeled as “used as a switch and not as a router?” (Yes, I know about the other thread: I started it. But, I am asking for the specific config entries below to be identified. For example, the AX3 has an IP, so it fails that test for “used only as a switch,” but the IP address is used for management of the AX3.)
How can I confirm that that the traffic flowing between wifi-connected user and the upstream device (the one that the ax3 is connected to) is going exclusively through the AX3’s switch chip (and not hitting the CPU)?
# 2025-04-22 05:43:10 by RouterOS 7.18.2
# software id = PTUN-M4Y8
# model = C53UiG+5HPaxD2HPaxD
# serial number = HEW09xxxx
add admin-mac=78:9A:18:30:D6:EE auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface wifi
add channel.band=5ghz-ax .skip-dfs-channels=disabled .width=20/40/80mhz \
configuration.mode=ap .ssid=ax3 disabled=no name=wifi1 radio-mac=\
78:9A:18:30:D6:F2 security.authentication-types=wpa2-psk,wpa3-psk
add channel.band=2ghz-ax .skip-dfs-channels=disabled .width=20/40mhz \
configuration.mode=ap .ssid=ax3 disabled=no name=wifi2 radio-mac=\
78:9A:18:30:D6:F3 security.authentication-types=wpa2-psk
add comment=defconf name=LAN
add comment=OffBridge name=OffBridge ranges=192.168.55.100-192.168.55.200
add address-pool=OffBridge interface=ether5 name=OffBridge
/system logging action
set 3 remote=127.0.0.1
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
add bridge=bridge interface=ether1
set udp-timeout=10s
/ipv6 settings
set disable-ipv6=yes forward=no
add interface=ether5 list=LAN
/interface ovpn-server server
add mac-address=FE:CD:A0:F7:0F:96 name=ovpn-server1
add address=192.168.0.13/24 comment=defconf interface=bridge network=\
192.168.0.0
add address=192.168.55.100/24 interface=ether5 network=192.168.55.0
/ip cloud
set ddns-enabled=yes
add address=192.168.55.0/24 dns-server=192.168.0.11 gateway=192.168.0.1
set allow-remote-requests=yes servers=192.168.0.11,9.9.9.9
/ip ipsec profile
/ip kid-control
add fri=0s-1d mon=0s-1d name=Monitor sat=0s-1d sun=0s-1d thu=0s-1d tue=0s-1d \
wed=0s-1d
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.0.11 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ip service
set www-ssl disabled=no
/ipv6 nd
/snmp
set enabled=yes trap-version=2
/system clock
set time-zone-name=America/New_York
/system identity
set name=355-hAPax3
/system note
set show-at-login=no
/system ntp client
set enabled=yes
/system ntp client servers
add address=0.north-america.pool.ntp.org
/tool mac-server
/tool mac-server mac-winbox
/tool romon
set enabled=yes id=78:9Axxxx
/tool sniffer
set filter-ip-address=192.168.2.0/24 filter-ip-protocol=icmp
