Ugh! I had to stick my fingers in it.
I upgrade an ax3 from 7.19.3 to 7.20.2.
All was working great at 7.19.3.
Now, I can’t connect to any of the 5ghz SSIDs.
I tried changing from AX to AC, I tried changing “Skip DFS Channels,” I tried connecting from multiple devices.
Then I tried running a wifi scan from another ax3 and it saw my 5ghz SSIDs – Sure seems like that means the primary ax3 was sending out announcements of its existance.
So I downgraded back to 7.19.3 and still my devices won’t connect. And still the other ax3 see the 5ghz SSIDs.
Can someone please help?
Here’s the export:
# 2025-10-26 13:19:58 by RouterOS 7.19.3
# software id = 5NRD-V1QF
# model = C53UiG+5HPaxD2HPaxD
# serial number = HDG0
add admin-mac=48:A9:8A:0F:04:8F ageing-time=5m arp=enabled arp-timeout=auto \
auto-mac=no comment=defconf dhcp-snooping=no disabled=no fast-forward=yes \
forward-delay=15s igmp-snooping=no max-learned-entries=auto \
max-message-age=20s mtu=auto mvrp=no name=bridge port-cost-mode=short \
priority=0x8000 protocol-mode=rstp transmit-hold-count=6 vlan-filtering=\
no
set [ find default-name=ether1 ] advertise="10M-baseT-half,10M-baseT-full,100M\
-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full,2.5G-baseT" arp=\
enabled arp-timeout=auto auto-negotiation=yes bandwidth=\
unlimited/unlimited comment="To RB5009" disabled=no l2mtu=1568 \
loop-protect=default loop-protect-disable-time=5m \
loop-protect-send-interval=5s mac-address=48:A9:8A:0F:04:8E mtu=1500 \
name=ether1 orig-mac-address=48:A9:8A:0F:04:8E poe-out=off poe-priority=\
10 power-cycle-interval=none !power-cycle-ping-address \
power-cycle-ping-enabled=no !power-cycle-ping-timeout rx-flow-control=off \
tx-flow-control=off
set [ find default-name=ether2 ] advertise="10M-baseT-half,10M-baseT-full,100M\
-baseT-half,100M-baseT-full,1G-baseT-half,1G-baseT-full" arp=enabled \
arp-timeout=auto auto-negotiation=yes bandwidth=unlimited/unlimited \
disabled=no l2mtu=1568 loop-protect=default loop-protect-disable-time=5m \
loop-protect-send-interval=5s mac-address=48:A9:8A:0F:04:8F mtu=1500 \
name=ether2 orig-mac-address=48:A9:8A:0F:04:8F rx-flow-control=off \
tx-flow-control=off
set [ find default-name=ether3 ] advertise="10M-baseT-half,10M-baseT-full,100M\
comment="TV - JRS-SRN" disabled=no l2mtu=1568 loop-protect=default \
loop-protect-disable-time=5m loop-protect-send-interval=5s mac-address=\
48:A9:8A:0F:04:90 mtu=1500 name=ether3 orig-mac-address=48:A9:8A:0F:04:90 \
rx-flow-control=off tx-flow-control=off
set [ find default-name=ether4 ] advertise="10M-baseT-half,10M-baseT-full,100M\
comment=TV disabled=no l2mtu=1568 loop-protect=default \
48:A9:8A:0F:04:91 mtu=1500 name=ether4 orig-mac-address=48:A9:8A:0F:04:91 \
set [ find default-name=ether5 ] advertise="10M-baseT-half,10M-baseT-full,100M\
comment=OffBridge disabled=no l2mtu=1568 loop-protect=default \
48:A9:8A:0F:04:92 mtu=1500 name=ether5 orig-mac-address=48:A9:8A:0F:04:92 \
/interface wifi
set [ find default-name=wifi1 ] arp-timeout=auto channel.band=5ghz-ax \
.skip-dfs-channels=disabled .width=20/40/80mhz configuration.country=\
"United States" .mode=ap .ssid=Upstairs5g-0F0493 disabled=no l2mtu=1560 \
mac-address=48:A9:8A:0F:04:93 name=wifi1 radio-mac=48:A9:8A:0F:04:93 \
security.authentication-types=wpa2-psk .ft=yes .ft-over-ds=yes
set [ find default-name=wifi2 ] arp-timeout=auto channel.band=2ghz-ax \
.secondary-frequency=2412 .skip-dfs-channels=disabled .width=20mhz \
configuration.country="United States" .mode=ap .ssid=Upstairs-2G-0F0494 \
disabled=no l2mtu=1560 mac-address=48:A9:8A:0F:04:94 name=wifi2 \
radio-mac=48:A9:8A:0F:04:94 security.authentication-types=wpa2-psk \
.connect-priority=0/1 .disable-pmkid=yes .ft=yes .ft-over-ds=yes \
.management-protection=disabled
/queue interface
set bridge queue=no-queue
/interface wifi
add arp-timeout=auto configuration.mode=ap .ssid=2point4 disabled=no l2mtu=\
1560 mac-address=4A:A9:8A:0F:04:93 master-interface=wifi2 mtu=1500 name=\
2point4 security.authentication-types=wpa2-psk .connect-priority=0/1 \
.disable-pmkid=yes .ft=yes .ft-over-ds=yes .management-protection=\
disabled
add arp-timeout=auto comment=JRS-Upstairs configuration.mode=ap .ssid=\
JRS-Upstairs disabled=no l2mtu=1560 mac-address=4A:A9:8A:0F:04:94 \
master-interface=wifi1 name=JRS-Upstairs security.authentication-types=\
wpa2-psk .disable-pmkid=yes .management-protection=disabled
add arp-timeout=auto configuration.mode=ap .ssid=blueberries disabled=yes \
l2mtu=1560 mac-address=4A:A9:8A:0F:04:96 master-interface=wifi1 name=\
blueberries security.authentication-types=wpa2-psk .disable-pmkid=yes \
/interface ethernet switch
set 0 !cpu-flow-control mirror-source=none mirror-target=none name=switch1
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
/interface ethernet switch port-isolation
set 0 !forwarding-override
set 1 !forwarding-override
set 2 !forwarding-override
set 3 !forwarding-override
set 4 !forwarding-override
set 5 !forwarding-override
set [ find name=all ] comment="contains all interfaces" exclude="" include="" \
name=all
set [ find name=none ] comment="contains no interfaces" exclude="" include="" \
name=none
set [ find name=dynamic ] comment="contains dynamic interfaces" exclude="" \
include="" name=dynamic
set [ find name=static ] comment="contains static interfaces" exclude="" \
include="" name=static
add comment=defconf exclude="" include="" name=WAN
add comment=defconf exclude="" include="" name=LAN
add exclude="" include=all name=TRUSTED
/interface lte apn
set [ find default=yes ] add-default-route=yes apn=internet authentication=\
none default-route-distance=2 ip-type=auto name=default use-network-apn=\
yes use-peer-dns=yes
/interface macsec profile
set [ find default-name=default ] name=default server-priority=10
/ip dhcp-client option
set clientid_duid code=61 name=clientid_duid value="0xff\$(CLIENT_DUID)"
set clientid code=61 name=clientid value="0x01\$(CLIENT_MAC)"
set hostname code=12 name=hostname value="\$(HOSTNAME)"
/ip hotspot profile
set [ find default=yes ] dns-name="" hotspot-address=0.0.0.0 html-directory=\
flash/hotspot html-directory-override="" http-cookie-lifetime=3d \
http-proxy=0.0.0.0:0 install-hotspot-queue=no login-by=cookie,http-chap \
name=default smtp-server=0.0.0.0 split-user-domain=no use-radius=no
/ip hotspot user profile
set [ find default=yes ] add-mac-cookie=yes address-list="" idle-timeout=none \
!insert-queue-before keepalive-timeout=2m mac-cookie-timeout=3d name=\
default !parent-queue !queue-type shared-users=1 status-autorefresh=1m \
transparent-proxy=no
add comment=offbridge-dhcp-server name=offbridge-dhcp-server ranges=\
192.168.55.100-192.168.55.200
# Interface not running
add address-lists="" address-pool=offbridge-dhcp-server comment=\
offbridge-dhcp-server disabled=no interface=ether5 lease-script="" \
lease-time=30m name=offbridge-dhcp-server use-radius=no use-reconfigure=\
no
/queue type
set 0 kind=pfifo name=default pfifo-limit=50
set 1 kind=pfifo name=ethernet-default pfifo-limit=50
set 2 kind=sfq name=wireless-default sfq-allot=1514 sfq-perturb=5
set 3 kind=red name=synchronous-default red-avg-packet=1000 red-burst=20 \
red-limit=60 red-max-threshold=50 red-min-threshold=10
set 4 kind=sfq name=hotspot-default sfq-allot=1514 sfq-perturb=5
set 5 kind=pcq name=pcq-upload-default pcq-burst-rate=0 pcq-burst-threshold=0 \
pcq-burst-time=10s pcq-classifier=src-address pcq-dst-address-mask=32 \
pcq-dst-address6-mask=128 pcq-limit=50KiB pcq-rate=0 \
pcq-src-address-mask=32 pcq-src-address6-mask=128 pcq-total-limit=2000KiB
set 6 kind=pcq name=pcq-download-default pcq-burst-rate=0 \
pcq-burst-threshold=0 pcq-burst-time=10s pcq-classifier=dst-address \
pcq-dst-address-mask=32 pcq-dst-address6-mask=128 pcq-limit=50KiB \
pcq-rate=0 pcq-src-address-mask=32 pcq-src-address6-mask=128 \
set 7 kind=none name=only-hardware-queue
set 8 kind=mq-pfifo mq-pfifo-limit=50 name=multi-queue-ethernet-default
set 9 kind=pfifo name=default-small pfifo-limit=10
/queue interface
set ether1 queue=only-hardware-queue
set ether2 queue=only-hardware-queue
set ether3 queue=only-hardware-queue
set ether4 queue=only-hardware-queue
set ether5 queue=only-hardware-queue
set "2point4" queue=wireless-default
set JRS-Upstairs queue=wireless-default
set blueberries queue=wireless-default
set wifi1 queue=wireless-default
set wifi2 queue=wireless-default
/snmp community
set [ find default=yes ] addresses=::/0 authentication-protocol=MD5 disabled=\
no encryption-protocol=DES name=public read-access=yes security=none \
write-access=no
/user group
set read name=read policy="local,telnet,ssh,reboot,read,test,winbox,password,w\
eb,sniff,sensitive,api,romon,rest-api,!ftp,!write,!policy" skin=default
set write name=write policy="local,telnet,ssh,reboot,read,write,test,winbox,pa\
ssword,web,sniff,sensitive,api,romon,rest-api,!ftp,!policy" skin=default
set full name=full policy="local,telnet,ssh,ftp,reboot,read,write,policy,test,\
winbox,password,web,sniff,sensitive,api,romon,rest-api" skin=default
add name=HA policy="reboot,read,write,policy,test,api,!local,!telnet,!ssh,!ftp\
,!winbox,!password,!web,!sniff,!sensitive,!romon,!rest-api" skin=default
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes comment=\
defconf disabled=no edge=auto fast-leave=no frame-types=admit-all \
horizon=none hw=yes ingress-filtering=yes interface=ether2 \
internal-path-cost=10 learn=auto multicast-router=temporary-query \
mvrp-applicant-state=normal-participant mvrp-registrar-state=normal \
path-cost=10 point-to-point=auto priority=0x80 pvid=1 restricted-role=no \
restricted-tcn=no tag-stacking=no trusted=no unknown-multicast-flood=yes \
unknown-unicast-flood=yes
horizon=none hw=yes ingress-filtering=yes interface=ether3 \
horizon=none hw=yes ingress-filtering=yes interface=ether4 \
horizon=none ingress-filtering=yes interface=wifi2 internal-path-cost=10 \
learn=auto multicast-router=temporary-query mvrp-applicant-state=\
normal-participant mvrp-registrar-state=normal path-cost=10 \
add auto-isolate=no bpdu-guard=no bridge=bridge broadcast-flood=yes disabled=\
no edge=auto fast-leave=no frame-types=admit-all horizon=none hw=yes \
ingress-filtering=yes interface=ether1 internal-path-cost=10 learn=auto \
multicast-router=temporary-query mvrp-applicant-state=normal-participant \
mvrp-registrar-state=normal path-cost=10 point-to-point=auto priority=\
0x80 pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=\
no unknown-multicast-flood=yes unknown-unicast-flood=yes
no edge=auto fast-leave=no frame-types=admit-all horizon=none \
ingress-filtering=yes interface=2point4 internal-path-cost=10 learn=auto \
ingress-filtering=yes interface=wifi1 !internal-path-cost learn=auto \
mvrp-registrar-state=normal !path-cost point-to-point=auto priority=0x80 \
pvid=1 restricted-role=no restricted-tcn=no tag-stacking=no trusted=no \
ingress-filtering=yes interface=blueberries !internal-path-cost learn=\
normal-participant mvrp-registrar-state=normal !path-cost point-to-point=\
auto priority=0x80 pvid=1 restricted-role=no restricted-tcn=no \
ingress-filtering=yes interface=JRS-Upstairs !internal-path-cost learn=\
/interface bridge settings
set allow-fast-path=yes use-ip-firewall=no use-ip-firewall-for-pppoe=no \
use-ip-firewall-for-vlan=no
set enabled=auto generic-timeout=10m icmp-timeout=10s loose-tcp-tracking=yes \
tcp-close-timeout=10s tcp-close-wait-timeout=10s tcp-established-timeout=\
1d tcp-fin-wait-timeout=10s tcp-last-ack-timeout=10s \
tcp-max-retrans-timeout=5m tcp-syn-received-timeout=5s \
tcp-syn-sent-timeout=5s tcp-time-wait-timeout=10s tcp-unacked-timeout=5m \
udp-stream-timeout=3m udp-timeout=10s
set discover-interface-list=TRUSTED discover-interval=30s \
lldp-mac-phy-config=no lldp-max-frame-size=no lldp-med-net-policy-vlan=\
disabled lldp-poe-power=yes lldp-vlan-info=no mode=tx-and-rx protocol=\
cdp,lldp,mndp
/ip settings
set accept-redirects=no accept-source-route=no allow-fast-path=yes \
arp-timeout=30s icmp-errors-use-inbound-interface-address=no \
icmp-rate-limit=10 icmp-rate-mask=0x1818 ip-forward=yes \
ipv4-multipath-hash-policy=l3 max-neighbor-entries=16384 rp-filter=no \
secure-redirects=yes send-redirects=yes tcp-syncookies=no tcp-timestamps=\
random-offset
/ipv6 settings
set accept-redirects=yes-if-forwarding-disabled accept-router-advertisements=\
yes-if-forwarding-disabled allow-fast-path=yes disable-ipv6=no \
disable-link-local-address=no forward=yes max-neighbor-entries=15360 \
min-neighbor-entries=3584 multipath-hash-policy=l3 \
soft-max-neighbor-entries=7168 stale-neighbor-detect-interval=30 \
stale-neighbor-timeout=60
/interface detect-internet
set detect-interface-list=none internet-interface-list=none \
lan-interface-list=none wan-interface-list=none
/interface l2tp-server server
set accept-proto-version=all accept-pseudowire-type=all allow-fast-path=no \
authentication=pap,chap,mschap1,mschap2 caller-id-type=ip-address \
default-profile=default-encryption enabled=no keepalive-timeout=30 \
l2tpv3-circuit-id="" l2tpv3-cookie-length=0 l2tpv3-digest-hash=md5 \
!l2tpv3-ether-interface-list max-mru=1450 max-mtu=1450 max-sessions=\
unlimited mrru=disabled one-session-per-host=no use-ipsec=no
add comment=defconf disabled=no interface=bridge list=LAN
add comment=defconf disabled=no interface=ether1 list=WAN
add disabled=no interface=bridge list=TRUSTED
add disabled=no interface=ether1 list=TRUSTED
add disabled=no interface=wifi2 list=TRUSTED
add comment=OffBridge disabled=no interface=ether5 list=LAN
add disabled=no interface=wifi1 list=TRUSTED
/interface lte settings
set esim-channel=auto firmware-path=firmware link-recovery-timer=120 mode=\
auto
/interface ovpn-server server
add auth=sha1,md5,sha256,sha512 certificate=*0 cipher=blowfish128,aes128-cbc \
default-profile=default disabled=yes enable-tun-ipv6=no ipv6-prefix-len=\
64 keepalive-timeout=60 mac-address=FE:20:83:39:29:80 max-mtu=1500 mode=\
ip name=ovpn-server1 netmask=24 port=1194 protocol=tcp push-routes="" \
redirect-gateway=disabled reneg-sec=3600 require-client-certificate=no \
tls-version=any tun-server-ipv6=:: user-auth-method=pap vrf=main
/interface pptp-server server
# PPTP connections are considered unsafe, it is suggested to use a more modern VPN protocol instead
set authentication=mschap1,mschap2 default-profile=default-encryption \
enabled=no keepalive-timeout=30 max-mru=1450 max-mtu=1450 mrru=disabled
/interface sstp-server server
set authentication=pap,chap,mschap1,mschap2 certificate=none ciphers=\
aes256-sha,aes256-gcm-sha384 default-profile=default enabled=no \
keepalive-timeout=60 max-mru=1500 max-mtu=1500 mrru=disabled pfs=no port=\
443 tls-version=any verify-client-certificate=no
/interface wifi access-list
add action=accept comment=HarmonyHub disabled=no mac-address=\
00:04:20:F9:31:D2
add action=accept comment=MFC-L3770 disabled=no mac-address=30:C9:AB:17:71:59
add action=accept comment="JRS iPhone" disabled=no mac-address=\
FC:AA:81:2A:1F:B4
add action=accept comment="\?\?\?" disabled=no mac-address=96:4E:A5:1A:A9:74
add action=accept comment="\?\?\?" disabled=no mac-address=52:DA:D4:46:23:5B
add action=accept comment="Thomas iPhone" disabled=no mac-address=\
46:B4:96:5E:1A:1B
add action=accept comment="SRN iPhone" disabled=no mac-address=\
4A:11:46:2B:5B:78
add action=accept comment="\?\?\?" disabled=no mac-address=02:2A:61:8A:88:A7
add action=accept comment="SRN iPad" disabled=no mac-address=\
16:31:50:11:6B:CF
add action=accept comment=DCP-L2550DW disabled=no mac-address=\
2C:6F:C9:5F:BC:EB
add action=accept comment=Laptop-JRS-AN51 disabled=no mac-address=\
94:E7:0B:29:30:E7
add action=accept comment="Tasmota switch" disabled=no mac-address=\
C4:5B:BE:E3:76:77
add action=accept comment="JRS Laptop 2023" disabled=no mac-address=\
64:49:7D:61:AE:2C
add action=accept comment="Living room (TV maybe)" disabled=no mac-address=\
D4:90:9C:D8:66:99
add action=accept comment="49TCLRokuTV - Thomas" disabled=no mac-address=\
0C:62:A6:1E:8B:18
add action=accept comment="SRN MS laptop" disabled=no mac-address=\
24:EE:9A:54:9A:E8
add action=accept comment=MFC-L2550 disabled=no mac-address=B2:38:0C:90:FE:04
add action=accept comment="THR316 Thomas BR" disabled=no mac-address=\
C8:F0:9E:E8:8A:E4
EA:C1:05:82:99:7C
add action=accept comment="THS Acer Laptop" disabled=no mac-address=\
54:6C:EB:7B:A2:C3
add action=accept comment="Screek Human Sensor 2A 16 LR" disabled=no \
mac-address=EC:DA:3B:D1:92:3C
add action=accept comment="Shelly Button1 15 AV Equip" disabled=no \
mac-address=48:55:19:F0:73:12
add action=accept comment="Beelink 212 DR" disabled=no mac-address=\
70:D8:C2:4C:54:64
add action=accept comment="JRS Iphone" disabled=no mac-address=\
7C:4B:26:5D:06:BE
add action=accept comment="Susan iPhone" disabled=no mac-address=\
60:57:C8:5D:06:4E
add action=accept comment=212-16-DR-Light-Tasmota disabled=no interface=\
2point4 mac-address=C4:5B:BE:DE:D0:8D
add action=accept comment="Amazon device" disabled=no interface=wifi1 \
mac-address=58:E4:88:97:C9:D1
add action=accept comment="Amazon Device" disabled=no interface=wifi1 \
mac-address=44:3D:54:A2:D1:14
mac-address=F0:F0:A4:FA:0E:B3
add action=accept comment="Amazon Device" disabled=no interface=2point4 \
mac-address=E8:4C:4A:CA:E9:AC
add action=accept comment=Watch disabled=no interface=wifi1 mac-address=\
D2:C6:1C:CB:64:8C
add action=accept comment="THS Iphone 2024" disabled=no interface=wifi1 \
mac-address=64:41:E6:0F:64:D2
add action=accept comment=iPad disabled=no interface=wifi1 mac-address=\
92:3B:B1:33:94:7D
F2:41:ED:13:C8:95
add action=accept comment="Cross Trainer 15" disabled=no interface=2point4 \
mac-address=E0:4F:43:82:2D:A0
/interface wifi cap
set enabled=no
/interface wifi capsman
set enabled=no
add address=192.168.2.5/24 comment=defconf disabled=no interface=bridge \
network=192.168.2.0
add address=192.168.55.1/24 comment=OffBridge disabled=no interface=ether5 \
network=192.168.55.0
/ip cloud
set back-to-home-vpn=revoked-and-disabled ddns-enabled=yes \
ddns-update-interval=none update-time=yes
/ip cloud advanced
set use-local-address=no
/ip dhcp-server config
set accounting=yes interim-update=0s radius-password=empty store-leases-disk=\
5m
add address=192.168.55.0/24 caps-manager="" dhcp-option="" dns-server=1.1.1.1 \
gateway=192.168.55.1 netmask=24 !next-server ntp-server="" wins-server=""
set address-list-extra-time=0s allow-remote-requests=yes cache-max-ttl=4w \
cache-size=4096KiB doh-max-concurrent-queries=50 \
doh-max-server-connections=5 doh-timeout=5s max-concurrent-queries=100 \
max-concurrent-tcp-sessions=20 max-udp-packet-size=4096 \
mdns-repeat-ifaces="" query-server-timeout=5s query-total-timeout=10s \
servers=192.168.2.2 use-doh-server="" verify-doh-cert=no vrf=main
/ip dns static
add address=192.168.2.5 comment=defconf disabled=no name=\
hapax3-upstairs.212.local ttl=1d type=A
ipsec-policy=out,none out-interface-list=WAN !to-addresses !to-ports
/ip firewall service-port
set ftp disabled=no ports=21
set tftp disabled=no ports=69
set irc disabled=yes ports=6667
set h323 disabled=no
set sip disabled=no ports=5060,5061 sip-direct-media=yes sip-timeout=1h
set pptp disabled=no
set rtsp disabled=yes ports=554
set udplite disabled=no
set dccp disabled=no
set sctp disabled=no
/ip hotspot service-port
/ip hotspot user
set [ find default=yes ] comment="counters and limits for trial users" \
disabled=no name=default-trial
/ip ipsec policy
set 0 disabled=no dst-address=::/0 group=default proposal=default protocol=\
all src-address=::/0 template=yes
/ip ipsec settings
set accounting=yes interim-update=0s xauth-use-radius=no
/ip media settings
set thumbnails=""
/ip nat-pmp
set enabled=no
/ip proxy
set always-from-cache=no anonymous=no cache-administrator=webmaster \
cache-hit-dscp=4 cache-on-disk=no cache-path=web-proxy enabled=no \
max-cache-object-size=2048KiB max-cache-size=unlimited \
max-client-connections=600 max-fresh-time=3d max-server-connections=600 \
parent-proxy=:: parent-proxy-port=0 port=8080 serialize-connections=no \
src-address=::
add disabled=no distance=1 dst-address=0.0.0.0/0 gateway=192.168.2.2 \
pref-src="" routing-table=main scope=30 suppress-hw-offload=no \
target-scope=10
/ip service
set ftp address="" disabled=yes max-sessions=20 port=21 vrf=main
set ssh address="" disabled=no max-sessions=20 port=22 vrf=main
set telnet address="" disabled=yes max-sessions=20 port=23 vrf=main
set www address="" disabled=yes max-sessions=20 port=80 vrf=main
set www-ssl address="" certificate=none disabled=no max-sessions=20 port=443 \
tls-version=any vrf=main
set winbox address="" disabled=no max-sessions=20 port=8291 vrf=main
set api address="" disabled=yes max-sessions=20 port=8728 vrf=main
set api-ssl address="" certificate=none disabled=no max-sessions=20 port=8729 \
/ip smb shares
set [ find default=yes ] directory=flash/pub disabled=yes invalid-users="" \
name=pub read-only=no require-encryption=no valid-users=""
/ip socks
set auth-method=none connection-idle-timeout=2m enabled=no max-connections=\
200 port=1080 version=4 vrf=main
/ip ssh
set always-allow-password-login=no ciphers=auto forwarding-enabled=no \
host-key-size=2048 host-key-type=rsa strong-crypto=no
/ip tftp settings
set max-block-size=4096
/ip traffic-flow
set active-flow-timeout=30m cache-entries=256k enabled=no \
inactive-flow-timeout=15s interfaces=all packet-sampling=no \
sampling-interval=0 sampling-space=0
/ip traffic-flow ipfix
set bytes=yes dst-address=yes dst-address-mask=yes dst-mac-address=yes \
dst-port=yes first-forwarded=yes gateway=yes icmp-code=yes icmp-type=yes \
igmp-type=yes in-interface=yes ip-header-length=yes ip-total-length=yes \
ipv6-flow-label=yes is-multicast=yes last-forwarded=yes nat-dst-address=\
yes nat-dst-port=yes nat-events=no nat-src-address=yes nat-src-port=yes \
out-interface=yes packets=yes protocol=yes src-address=yes \
src-address-mask=yes src-mac-address=yes src-port=yes sys-init-time=yes \
tcp-ack-num=yes tcp-flags=yes tcp-seq-num=yes tcp-window-size=yes tos=yes \
ttl=yes udp-length=yes
/ip upnp
set allow-disable-external-interface=no enabled=no show-dummy-rule=yes
/ipv6 nd
set [ find default=yes ] advertise-dns=yes advertise-mac-address=yes \
disabled=no hop-limit=unspecified interface=all \
managed-address-configuration=no mtu=unspecified other-configuration=no \
ra-delay=3s ra-interval=3m20s-10m ra-lifetime=30m ra-preference=medium \
reachable-time=unspecified retransmit-interval=unspecified
/ipv6 nd prefix default
set autonomous=yes preferred-lifetime=1w valid-lifetime=4w2d
/mpls settings
set allow-fast-path=yes dynamic-label-range=16-1048575 propagate-ttl=yes
/ppp aaa
set accounting=yes enable-ipv6-accounting=no interim-update=0s \
use-circuit-id-in-nas-port-id=no use-radius=no
/radius incoming
set accept=no port=3799 vrf=main
/routing igmp-proxy
set query-interval=2m5s query-response-interval=10s quick-leave=no
/routing settings
set single-process=no
/snmp
set contact="" enabled=yes engine-id-suffix="" location="" src-address=:: \
trap-community=public trap-generators=temp-exception trap-target="" \
trap-version=2 vrf=main
/system clock
set time-zone-autodetect=yes time-zone-name=America/New_York
/system clock manual
set dst-delta=+00:00 dst-end="1970-01-01 00:00:00" dst-start=\
"1970-01-01 00:00:00" time-zone=+00:00
/system health settings
set cpu-overtemp-check=no cpu-overtemp-startup-delay=1m \
cpu-overtemp-threshold=105C
/system identity
set name=212hAPax3-upstairs
/system leds
set 0 disabled=no leds=poe-led type=poe-out
set 1 disabled=no interface=ether1 leds=led1 type=interface-activity
set 2 disabled=no interface=ether2 leds=led2 type=interface-activity
set 3 disabled=no interface=ether3 leds=led3 type=interface-activity
set 4 disabled=no interface=ether4 leds=led4 type=interface-activity
set 5 disabled=no interface=ether5 leds=led5 type=interface-activity
/system leds settings
set all-leds-off=never
/system logging
set 0 action=memory disabled=no prefix="" regex="" topics=info
set 1 action=memory disabled=no prefix="" regex="" topics=error
set 2 action=memory disabled=no prefix="" regex="" topics=warning
set 3 action=echo disabled=no prefix="" regex="" topics=critical
add action=memory disabled=no prefix="" regex="" topics=account
add action=remote disabled=no prefix="192.168.2.5 " regex="" topics=info
add action=email disabled=no prefix=ether3-monitor regex="ether3 link down" \
topics=info
/system note
set note="" show-at-cli-login=no show-at-login=no
/system ntp client
set enabled=yes mode=unicast servers=\
192.168.2.2,3.pool.ntp.org,0.north-america.pool.ntp.org vrf=main
/system ntp server
set auth-key=none broadcast=no broadcast-addresses="" enabled=no \
local-clock-stratum=5 manycast=no multicast=no use-local-clock=no vrf=\
main
/system ntp client servers
add address=192.168.2.2 auth-key=none disabled=no iburst=yes max-poll=10 \
min-poll=6
add address=3.pool.ntp.org auth-key=none disabled=no iburst=yes max-poll=10 \
min-poll=6
add address=0.north-america.pool.ntp.org auth-key=none disabled=no iburst=yes \
max-poll=10 min-poll=6
/system package local-update mirror
set check-interval=1d enabled=no primary-server=0.0.0.0 secondary-server=\
0.0.0.0 user=""
/system resource usb settings
set authorization=no
/system routerboard mode-button
set enabled=no hold-time=0s..1m on-event=""
/system routerboard reset-button
/system routerboard settings
set auto-upgrade=no boot-device=nand-if-fail-then-ethernet boot-protocol=\
bootp force-backup-booter=no preboot-etherboot=disabled \
preboot-etherboot-server=any protected-routerboot=disabled \
reformat-hold-button=20s reformat-hold-button-max=10m silent-boot=no
/system routerboard wps-button
/system watchdog
set auto-send-supout=yes automatic-supout=yes ping-start-after-boot=10m \
ping-timeout=5m send-email-to=jXXXXX@domain.com watch-address=\
1.1.1.1 watchdog-timer=yes
/tool e-mail
set from=jXXXXX@domain.com port=587 server=smtp.gmail.com tls=starttls \
user=<user>@gmail.com vrf=main
/tool graphing
set page-refresh=300 store-every=5min
/tool mac-server
/tool mac-server mac-winbox
set allowed-interface-list=TRUSTED
/tool mac-server ping
set enabled=yes
/tool romon
set enabled=yes id=00:00:00:00:00:00
/tool romon port
set [ find default=yes ] cost=100 disabled=no forbid=no interface=all
