I’ve moved on from the bottleneck issue (other thread) – which means I can’t stop focusing on the wifi channel issue.
I have reset the radio provisioning and recreated the wifi interface for 5ghz.
Tried 5Ghz N, AC, and AX
Left the Channel Width empty.
And tried all frequencies from 5160 to 5885 in 20mhz increments. The only 2 that do not produce the error are 5180 and 5745 (even with the channel width left empty).
Normal MT wifi experience…Why I use another vendors product for wifi. I mean it will work well once you figure it out, but for me personally not worth the stress to get there.
I am also lazy and dont like dealing with capsman.
But I must agree with @anav here, with other vendors you will get much more smoother Wi-Fi experience. With Mikrotik it’s just frustrating sometimes to get Wi-Fi to work right…
Well, then set this to skip-dfs-channels=disabled … only then will your ax3 try to use DFS channels (note the wording of property, it includes “skip”).
