I’m just testing the following scenario:
IPSEC site to site VPN Mikrotik to Azure
RB951G-2HnD firmware 3.41 ROS 6.40.8 in the onpremises side
VpnGw1 in the Azure side
When I copy a file from an onpremises Windows to other Windows in the cloud the router’s CPU goes to 100% and the throughput is about 28Mb/s.
Any idea why I’m getting such as ridiculous throughput?
PS: The configuration in the onpremises side is thisone:
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-128-cbc lifetime=7h30m pfs-group=none
/ip firewall
nat add action=accept chain=srcnat dst-address=172.16.0.0/23 src-address=192.168.100.0/24 place-before=0 comment=AzureNAT
/ip firewall raw
add action=notrack chain=prerouting src-address=172.16.0.0/23 dst-address=192.168.100.0/24
add action=notrack chain=prerouting src-address=192.168.100.0/24 dst-address=172.16.0.0/23
/ip ipsec peer
add address=/32 dh-group=modp1024 enc-algorithm=aes-256,aes-128 exchange-mode=ike2 secret= lifetime=8h
/ip ipsec policy
set 0 disabled=yes
add dst-address=172.16.0.0/23 sa-dst-address=****** sa-src-address=******** src-address=192.168.100.0/24 tunnel=yes
Regards.
