The SXT lite is properly connected and with good signal but LEDs are off.
Is a limitation of this model?
The other SXT model leds, works fine.
is it in station mode, or something else?
AFAIK the LEDs only work in the station modes.
It would be nice if the LEDs worked in Bridge mode (only allows 1 client) as well, but I don’t think they do ?
Nick.
Yes, I try with 3 SXT 5nD r2, and nothing…
Router OS 5.24 and 5.25
Yes, they are in station bridged mode.
I’ve been installing SXT for months, and I have only this problem with the SXT Lite (configuration is identical to that of the other antennas)
like it was said, LEDS only work in “station” mode, not ap-bridge, bridge or other modes.
yes, they are in station mode, like others working SXT (not lite). Only fail in SXT Lite
Are you using RouterOS v5.25 and latest RouterBOOT? Also make sure you have not reset the ‘/system led’ configuration. You can also manually configure them there.
Yes, 5.25 and 3.07.
I honestly do not see /system led, because I had never needed to touch … I’ll take a look
Indeed, I have “/system led” empty. I do not know why, this with the default settings, I never touch that.
thank you very much
Upgrade to newest v6 release and do “/system reset” to fix it.
