Back To Home VPN - spamming logs when disconnected
I have recently set up Back To Home VPN using the mobile app and it’s working very well, however I noticed that consistently around every 2 minutes (± 10 seconds) there seems to be this message added to Log (I am not trying to connect at this time! the vpn is not connected!)
back-to-home-vpn: [peer2] <WIREGUARDPEERPUBLICKEY>: Handshake for peer did not complete after 20 attempts, giving up
where instead of there’s the public key.
When I disabled and revoked BTH VPN in IP > Cloud > BTH VPN the message went away, but it of course removed my access. I do not have other WireGuard interfaces / peers, only BTH.
I observed this issue on a hAP ax2 running RouterOS 7.15 and RouterBOARD Firmware 7.15.
I had the same problem with wireguard log spam. We solved it by add !wireguard in log. → http://forum.mikrotik.com/t/log-show-to-much-info-ver-7-14-3/176201/1
You can use terminal method by rextended or winbox way by me (follow picture). Both do the same.
Disappointing that MT did not fix this well known issue for the release of 7.15.
