I'm just new here, I am using a mikrotik hap ax2, and I have downloaded the bth android app and did the configuration as per the bth documentation, but is stating that VPN connection failed. Any help please
What exact bth documentation are you referring to?
It is difficult to provide information without insights on your device.
Can you share the current config?
/export file=anynameyoulike
Remove serial and any other private info (public IP, etc.), post as Preformatted text by using the </> button.
