I have configured the ‘Back to Home’ VPN, which seems to be working on my iOS devices. This allows me to access my router and LAN devices whenever I am staying at a hotel. However, I would also like to enable public internet access for the VPN. What is the best way to configure this? Any help would be greatly appreciated. I have attached my configuration file.
# 2024-02-05 14:33:08 by RouterOS 7.13.3
# software id = 79VK-VRAH
# model = RB5009UPr+S+
# serial number = xxxxxxxxxxx
add name=bridge-local port-cost-mode=short
set [ find default-name=ether1 ] poe-out=off
/interface wireguard
add comment=back-to-home-vpn listen-port=45415 mtu=1420 name=back-to-home-vpn
/interface vlan
add interface=ether1 loop-protect=off name=vlan1.6 vlan-id=6
/interface pppoe-client
add add-default-route=yes allow=pap disabled=no interface=vlan1.6 keepalive-timeout=20 max-mru=1500 max-mtu=1500 name=pppoe-client user=00-4A-77-6A-43-50@internet
add name=LAN
add name=WAN
add name=dhcp_pool0 ranges=192.168.0.100-192.168.0.254
add address-pool=dhcp_pool0 interface=bridge-local lease-time=10m name=dhcp1
/ppp profile
set *0 only-one=yes use-compression=yes use-upnp=no
/snmp community
set [ find default=yes ] addresses=192.168.0.0/24
add bridge=bridge-local interface=ether2 internal-path-cost=10 path-cost=10
add bridge=bridge-local ingress-filtering=no interface=ether3 internal-path-cost=10 path-cost=10
add bridge=bridge-local ingress-filtering=no interface=ether4 internal-path-cost=10 path-cost=10
add bridge=bridge-local ingress-filtering=no interface=ether5 internal-path-cost=10 path-cost=10
add bridge=bridge-local ingress-filtering=no interface=ether6 internal-path-cost=10 path-cost=10
add bridge=bridge-local ingress-filtering=no interface=ether7 internal-path-cost=10 path-cost=10
add bridge=bridge-local ingress-filtering=no interface=ether8 internal-path-cost=10 path-cost=10
add bridge=bridge-local ingress-filtering=no interface=sfp-sfpplus1 internal-path-cost=10 path-cost=10
add interface=ether2 list=LAN
add interface=ether3 list=LAN
add interface=ether4 list=LAN
add interface=ether5 list=LAN
add interface=ether6 list=LAN
add interface=ether7 list=LAN
add interface=ether8 list=LAN
add interface=sfp-sfpplus1 list=LAN
add interface=pppoe-client list=WAN
/interface wireguard peers
add allowed-address=192.168.216.4/32 comment="RB5009UPr+S+ (iPhone16,2)" interface=back-to-home-vpn public-key="xxxxxxxxxxxxxxxxx"
add address=192.168.0.1/24 interface=bridge-local network=192.168.0.0
/ip cloud
set back-to-home-vpn=enabled ddns-enabled=yes
add address=192.168.0.0/24 dns-server=192.168.0.1 gateway=192.168.0.1
set allow-remote-requests=yes servers=8.8.8.8,8.8.4.4
/ip dns static
add address=192.168.0.4 name=diskstation
/ip firewall address-list
add address=192.168.0.2-192.168.0.254 list=allowed_to_router
add address=0.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=172.16.0.0/12 comment=RFC6890 list=not_in_internet
add address=192.168.0.0/16 comment=RFC6890 list=not_in_internet
add address=10.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=169.254.0.0/16 comment=RFC6890 list=not_in_internet
add address=127.0.0.0/8 comment=RFC6890 list=not_in_internet
add address=224.0.0.0/4 comment=Multicast list=not_in_internet
add address=198.18.0.0/15 comment=RFC6890 list=not_in_internet
add address=192.0.0.0/24 comment=RFC6890 list=not_in_internet
add address=192.0.2.0/24 comment=RFC6890 list=not_in_internet
add address=198.51.100.0/24 comment=RFC6890 list=not_in_internet
add address=203.0.113.0/24 comment=RFC6890 list=not_in_internet
add address=100.64.0.0/10 comment=RFC6890 list=not_in_internet
add address=240.0.0.0/4 comment=RFC6890 list=not_in_internet
add address=192.88.99.0/24 comment="6to4 relay Anycast [RFC 3068]" list=not_in_internet
add action=accept chain=input comment="default configuration" connection-state=established,related
add action=accept chain=input src-address-list=allowed_to_router
add action=drop chain=input
add action=fasttrack-connection chain=forward comment=FastTrack connection-state=established,related hw-offload=yes
add action=accept chain=forward comment="Established, Related" connection-state=established,related
add action=drop chain=forward comment="Drop invalid" connection-state=invalid log=yes log-prefix=invalid
add action=drop chain=forward comment="Drop tries to reach not public addresses from LAN" dst-address-list=not_in_internet in-interface=bridge-local log=yes log-prefix=!public_from_LAN out-interface=!bridge-local
add action=drop chain=forward comment="Drop incoming packets that are not NAT`ted" connection-nat-state=!dstnat connection-state=new in-interface=ether1 log=yes log-prefix=!NAT
add action=jump chain=forward comment="jump to ICMP filters" jump-target=icmp protocol=icmp
add action=drop chain=forward comment="Drop incoming from internet which is not public IP" in-interface=ether1 log=yes log-prefix=!public src-address-list=not_in_internet
add action=drop chain=forward comment="Drop packets from LAN that do not have LAN IP" in-interface=bridge-local log=yes log-prefix=LAN_!LAN src-address=!192.168.0.0/24
add action=drop chain=input dst-port=8080 in-interface=ether1 protocol=tcp src-address=0.0.0.0/0
/ip proxy
set cache-administrator=xxxxx max-cache-object-size=50000KiB src-address=192.168.0.1
/ip upnp
set show-dummy-rule=no
/ipv6 address
add address=::1 from-pool=kpn-pool interface=bridge-local
/ipv6 dhcp-client
add add-default-route=yes interface=pppoe-client pool-name=kpn-pool pool-prefix-length=48 request=prefix use-peer-dns=no
/ipv6 firewall address-list
add address=fe80::/16 list=allowed
add address=ff02::/16 comment=multicast list=allowed
/ipv6 firewall filter
add action=accept chain=input comment="allow established and related" connection-state=established,related
add action=accept chain=input comment="accept ICMPv6" protocol=icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=33434-33534 protocol=udp
add action=accept chain=input comment="accept DHCPv6-Client prefix delegation." dst-port=546 protocol=udp src-address=fe80::/16
add action=accept chain=input comment="allow allowed addresses" src-address-list=allowed
add action=drop chain=input in-interface=pppoe-client log=yes log-prefix=dropLL_from_public src-address=fe80::/16
/ipv6 nd
set [ find default=yes ] interface=bridge-local
/routing igmp-proxy interface
add interface=bridge-local
/system clock
set time-zone-name=Europe/Amsterdam
/system note
set show-at-login=no
