Back up link
Hello.
I am connecting with internet via mikrotik.
Is it possible that all the traffic to internet (vice versa) pass throw a backup line (2nd line to internet) when the first path (line) is down? Please, how can I do?
I’ll welcome any solution.
Thank You.
You can achive this by adding the second gateway with higher metric meaning distance=5 e.g and also allow check-gateway=ping in both default routes. With this as soon as primary link goes down it will activate the back-up link, than as soon as primary link comes up you will be redirected through primary link.
Regards.
Faton
Thank you Faton. I’ll try it.
Faleminderit. Po te shkruaj edhe ne shqip meqe jemi shqipetar. Une jam nga Tirana.
