If you make a back up. What will be in the back up. Is it only devices or is it everything you configured in the Dude?
Kinds Regards
Tim Siera
Kinds Regards
Tim Siera
The backup is an XML file that contains your configuration of the Dude. It pretty much contains references to everything about the configuration and what is displayed on the map. You can view it by opening it in a browser window or notepad, or an XML editor of your choosing.
What about historical data? Anyway to back that up?
Can you define what you mean by historical data?
