Background scan done remotely and problems with it
My first post here so hello everybody,
I have a problem, I am using this command to get scan results remotely: interface wireless scan wlan6 duration=120 save-file=scan.txt. Commands works but the problem is that results seems to be not from whole scan list range which is set to 4900-6100 yet it seems to scan only to frequency that antenna is connected to, for example its connected on 5240 and I get scan results only from frequencies up to 5260 like nothing was above so the scan is limited to 4900-5260 instead of scanning 4900-6100. How can I change that and what might be causing this ?
Would really apriciate your help
Bump cause i could really need your help with this
Make sure you have not set any scan lists on wireless interface
So how should it be set ? In wireless tab in scan list i have it manually to “4900-6100” ? Should i change it to default ?
