I have a device that is based on the MikroTik Routerboard 450 that is starting to fail intermittently. (It overheats in about 2 hours of use). When it gets “hot” it stops working.
The manufacturer says its out of warranty. This is my 3rd device from them and a little unhappy about the fact that failures keep happening. (The first two times was a power supply issue).
In any case my question is while this device is still running and not overheating, can I back it all up and restore it on a new Routerboard 450? That way I can have a functioning device again that I can rely on.
Rizwan
Use the export command.
Export compact file %name%
then
import %file%
on the new box.
Just a note: “export compact” works only from RouterOS 5.12… In case the RB450 has an older version of RouterOS you must update (the new one too, I would suggest…)
For identical devices also binary backup/restore works fine.
In Winbox select ‘Files’, next ‘Backup’ button.
Copy created backup file to second router and use ‘Files/Restore’.
As maxstel suggested before backup/restore, upgrade RouterOS on both devices to same, latest version.
HTH,
How do I get to where I can use this command?
I tried to telnet into it by using the IP address the DHCP server on the network assigned it. I can sign onto the proprietary software’s interface (not Mikrotik interface) through a browser. I also tried connecting via COM1 and still got only into the proprietary software’s menu (which allows to reset all the ip addresses for their software, do a reset, etc.)
Its like the Mikrotik OS is not there anymore. I thought maybe there is Mikrotik OS that boots the device up partially and hands it over to the custom software – but I can’t see any evidence of that.
I also tried Winbox but the RB450 does not respond to Winbox on its ip address, yet, again I can access the web interface through https.
What can I try next?
