As Znevena noted there is no automated way to switch the config over.
One should know what they are doing…
I would advise that you enter the default setup of the 5009 and take one port off the bridge and
then do all your configs from this port to avoid getting locked out while making the changes and of course heavy use of Safe mode.
I did something similar recently. Not too bad (and I was going from 6.x to 7.x at the same time, changing numbers of ports etc.), though there were a few things that needed fixing up. Export compact will avoid a lot of cruft and just give you what you have changed - much easier to review/edit.
I had a first cut at editing the export file to ready it for the new router, then executed it automatically (rather than step by step) from a clean configuration with
Then look in the log to work out to see where the import has stopped, experiment interactively, and tweak script as necessary, repeat until it runs clean. I did have to reset physically a couple of times when I screwed up, so may not be a good approach if you’re remote or if you need to minimise downtime. As suggested up the thread, I ensured that one port wasn’t bridged in the config and connected via that.
Enabling the following early in the config script
/tool mac-server mac-winbox
set allowed-interface-list=<something suitable>
Can save a lot of time by enabling you to admin the router even if TCP/IP is not functional, as long as you’re on the same (V)LAN.
