Backup and restore configuration
Hi Guys,
I have made a backup configuration of RB433AH with two radio (one XR5 and one R52H) and with 3.18 routerOS version. Then I have made a restore on RB600 with two radio (one XR5 and one R52H) and with the same routerOS version.
Now I have these problems on radio configuration:
  1. Interface name is wlan1 and not the interface name of RB433AH
  2. SSID is the radio name of RB433AH and not the SSID
  3. All other fields seems to be set to default
Can you help me please?
Another question: Are there problems if restore is made to routerboard that has different interface (in number and model)?
Thank you very much
Best regards
yes, the wired and wireless configs go with the MAC addresses of the cards …
OK, and so? Did you not answer to my question about radio configuration?
Please help me
Regards
Sorry. There isnt a solution at the moment. You have to manually export wireless configs and then paste them into terminal to get back same configuration.
/int wireless export
Sam
