Backup and restore only DHCP LEASE and QUEUE part of config?
Cześć Bartosz,
No spaces in names.
Zrzut ekranu 2026-06-22 203635
The script worked for a while. Triggered manually. Scheduled, it sometimes worked, sometimes didn't. Now it's completely broken again.
Zrzut ekranu 2026-06-22 203940
If you do that, then everything will be fine:
file=("$plik.rsc","$plik.backup")
:wink:
Try to insert a :delay 5; line between the /system backup... and /tool e-mail... lines. It could be that recent RouterOS versions made the export or backup commands asynchronous, and the calls might return before the files are fully written to storage.
I use a delay of 1 sec and it works fine for years...
... but 1 or 5 sec is not so important.
It's working so far. Thanks a lot.
I've tried different syntaxes for "file" command before, but they didn't work, unless I did something wrong.
I'm surprised the original script works without any tweaks on hap ac2. I don't know what it depends on.
Thanks for further improvement.
Many thanks for your effort, time and many ideas.
You are welcome.
